  • Topic author was deleted
    Jul 10, 2013 @ 11:11
    Contour 3.0.14 changes
    Contour 3.0.14 is out today!
    It only contains a single fix that takes care of issue http://issues.umbraco.org/issue/CON-397
    So if you encountered the following error when using Contour 3.0.13
    Could not load type 'System.Runtime.CompilerServices.ExtensionAttribute' from assembly 'mscorlib, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089'.
    More details on the issue here http://our.umbraco.org/forum/umbraco-pro/contour/42981-Could-not-load-type-SystemRuntimeCompilerServicesExtensionAttribute-from-assembly-mscorlib
    You can get it from the project page http://our.umbraco.org/projects/umbraco-pro/contour
    Upgrade instructions available here http://our.umbraco.org/projects/umbraco-pro/contour/documentation/Installation/Upgrade
  • David Brendel 792 posts 2970 karma points MVP 3x c-trib
    Jul 11, 2013 @ 10:17
    David Brendel
    New version works!
    Thanks for the super fast fix.
  • Comment author was deleted
    Jul 11, 2013 @ 10:40
    Great! Thanks for confirming @David :)
