  • David 11 posts 122 karma points
    Jul 11, 2013 @ 22:50
    David
    Conditions on multi-lingual strings on Contour form
    I'm trying to set up a condition of showing a radiobutton list (list name is #contactFormManager which is a bilingual term) when an item of of the other radiobutton list is selected. But it does not seem to work if the item is using a dictionary item (#labelManager).
    The condition is:
    (Show) this field if (All) of the following match:
    #contactFormManager (IS) #labelManager
    Am I doing the syntax right?  Or is this supported in Contour?
    Many thanks!
  • Comment author was deleted
    Jul 12, 2013 @ 21:22
    Hmm might be that the dictionary items aren't supported yet for that one, will take a look on monday
    Jul 12, 2013 @ 22:23
    David
    Great! Thanks Tim!
    Jul 15, 2013 @ 11:00
    Yeah I can confirm that the conditions don't support dictionary items at this point, will provide a fix for it today :)
    Jul 15, 2013 @ 11:06
    Ok found the fix, you'll just need to update the \Umbraco\Plugins\umbracoContour\Views\Script.cshtml file
    With the new version found here
    https://www.dropbox.com/s/cqogiq8f7o7sma4/Script.cshtml
    Jul 15, 2013 @ 11:08
    Will be part of 3.0.15 issue here http://issues.umbraco.org/issue/CON-402
    Jul 17, 2013 @ 19:54
    David
    Hi Tim!
    It is working on preview page, but it is not working on the actual page. I wonder if there is anything else that I need to do?
    Many thanks,
    ~David
    Jul 17, 2013 @ 19:59
    Are you using the razor macro since conditions only work on that one :)
    Jul 17, 2013 @ 20:00
    Jul 17, 2013 @ 20:12
    David
    Oh brilliant! It is working now after I have included the script references on my template!
    Thank you so much!!! :)
    Jul 17, 2013 @ 20:13
    Great, glad it's working :)
