RadioButtonList with Edit Items with Multiline or RichTextEditor
I'm extending the Contour Fieldtype for a quiz/training module. I've manage to create all things I need. The control I wish to make is a list of items to be put in the right order. So I using the RadioButtonList
However the 'Edit Items' for a RadioButtonList/CheckBoxList in the backend in Umbraco, I would like override the textboxes with Multiline textboxes or even RichTextEditor so I can use images.
The 'WebControl Editor' has no effect when I override. Is there another way ?
public class OrderList : Umbraco.Forms.Core.Providers.FieldTypes.RadioButtonList
public override WebControl Editor
get
if (Value.Count > 0)
txt.Text = Value[0].ToString();
txt.Culture = Culture;
txt.CheckSpellingCaption = CheckSpellingCaption;
txt.LoadingCaption = LoadingCaption;
txt.NoMistakesCaption = NoMistakesCaption;
return txt;
set { base.Editor = value; }
public override string RenderPreviewWithPrevalues(List<object> prevalues)
I would like to have a RichTextEditor for the Prevalues in the backend. I've extended the TextBox class, I've try Tinymce control and HtmlEditorExtender (which I got a bit further) however the HTML content won't save when I save the form in Contour.
using System;
using System.Linq;
using System.Web;
using AjaxControlToolkit;
using AjaxControlToolkit.Sanitizer;
using System.Web.UI.WebControls;
namespace Application.Web.FieldSetting
/// http://our.umbraco.org/forum/umbraco-pro/contour/12375-How-to-create-a-new-FieldSettingType
public class RichTextEditor : Umbraco.Forms.Core.FieldSetting.TextArea
public Guid ObjectGuid { get; set; }
// public umbraco.editorControls.tinyMCE3.webcontrol.TinyMCEWebControl tinymce = new umbraco.editorControls.tinyMCE3.webcontrol.TinyMCEWebControl();
private TextBox tb = new TextBox();
public RichTextEditor()
ObjectGuid = new Guid("a2cb7830-f571-4787-9638-bc48539a0efb");
//tinymce.SkinID = "umbraco";
public override string Value
get
return tinymce.Text;
set
tinymce.Text = value;
get
return tb.Text;
set
tb.Text = value;
public override System.Web.UI.WebControls.WebControl RenderControl(Umbraco.Forms.Core.Attributes.Setting sender, Umbraco.Forms.Core.Form form)
tinymce.ID = sender.GetName();
tinymce.CssClass = "tinymceContainer";
tinymce.Visible = true;
///umbraco_client/tinymce3/themes/umbraco/skins/umbraco/ui.css
if (string.IsNullOrEmpty(tinymce.Text) && Prevalues.Count > 0)
tinymce.Text = Prevalues[0];
return tinymce;
tb.ID = sender.GetName();
tb.TextMode = TextBoxMode.MultiLine;
tb.Width = 600;
tb.Height = 200;
// tb.CssClass = "guiInputText guiInputStandardSize";
if (string.IsNullOrEmpty(tb.Text) && Prevalues.Count > 0)
tb.Text = Prevalues[0];
HtmlEditorExtender htmlEditorExtender = new HtmlEditorExtender();
htmlEditorExtender.ID = "htmlextender_" + sender.GetName();
htmlEditorExtender.TargetControlID = sender.GetName();
WebControl webctrl = new WebControl(System.Web.UI.HtmlTextWriterTag.Div);
webctrl.Controls.Add(tb);
webctrl.Controls.Add(htmlEditorExtender);
return webctrl;
Field in the form part for a four questions ( Images/Text etc..., the user need to decide with image to choose etc...
using System;
using System.Linq;
using System.Web;
using Umbraco.Forms.Core;
using System.IO;
using System.Text;
using umbraco.editorControls;
using umb = umbraco;
namespace Application.Web.FieldType
public class FourQuestions : Umbraco.Forms.Core.FieldType
public List
Thank you for answering me back. I couldn't get the TinyMce Umbraco control to render properly for a FieldType.
So I used the HTMLEditrorExtender from the AjaxToolKit with the standard TextArea control. It renders in correct in Contour however it won't save or load values into the HTMLExtended TextArea.
What I need is a way to have HTML in Prevalues via a FieldType, however Umbraco strips out HTML code. Probably via AntiXSS module, even tried .NET 4.5 and setting the TextArea to System.Web.UI.ValidateRequestMode.Disabled. This makes no differences.
get
return txt;
string o = string.Empty;
int i = 1;
foreach (var item in prevalues)
o += @"<div style=""width:150px;height:150px;border:1px solid #d0d0d0;text-align:center;float:left;margin:5px;display:block;font-size: 80px;line-height: 140px;cursor:move;"">" + i.ToString() + "</div>";
i++;
return o + @"<div style=""clear:both""></div>";
Comment author was deleted
Hey Gavin,
You are probably using the razor macro that doesn't make use of the webcontrol, for an example of a razor only fieldtype check out this thread
http://our.umbraco.org/forum/umbraco-pro/contour/40417-Creating-custom-FieldType-with-multiple-SingleLine-textboxes
You might also be able to do this by just customizing the views for details on that check
http://our.umbraco.org/projects/umbraco-pro/contour/documentation/Developer/Custom-Markup/
Hi Tim,
using System; using System.Collections.Generic; using System.Linq; using System.Web; using AjaxControlToolkit; using AjaxControlToolkit.Sanitizer; using System.Web.UI.WebControls; namespace Application.Web.FieldSetting { /// /// http://our.umbraco.org/forum/umbraco-pro/contour/12375-How-to-create-a-new-FieldSettingType /// public class RichTextEditor : Umbraco.Forms.Core.FieldSetting.TextArea { public Guid ObjectGuid { get; set; } // public umbraco.editorControls.tinyMCE3.webcontrol.TinyMCEWebControl tinymce = new umbraco.editorControls.tinyMCE3.webcontrol.TinyMCEWebControl(); private TextBox tb = new TextBox(); public RichTextEditor() { ObjectGuid = new Guid("a2cb7830-f571-4787-9638-bc48539a0efb"); //tinymce.SkinID = "umbraco"; } /* public override string Value { get { return tinymce.Text; } set { tinymce.Text = value; } } */ public override string Value { get { return tb.Text; } set { tb.Text = value; } } public override System.Web.UI.WebControls.WebControl RenderControl(Umbraco.Forms.Core.Attributes.Setting sender, Umbraco.Forms.Core.Form form) { /* tinymce.ID = sender.GetName(); tinymce.CssClass = "tinymceContainer"; tinymce.Visible = true; ///umbraco_client/tinymce3/themes/umbraco/skins/umbraco/ui.css if (string.IsNullOrEmpty(tinymce.Text) && Prevalues.Count > 0) tinymce.Text = Prevalues[0]; return tinymce; */ tb.ID = sender.GetName(); tb.TextMode = TextBoxMode.MultiLine; tb.Width = 600; tb.Height = 200; // tb.CssClass = "guiInputText guiInputStandardSize"; if (string.IsNullOrEmpty(tb.Text) && Prevalues.Count > 0) tb.Text = Prevalues[0]; HtmlEditorExtender htmlEditorExtender = new HtmlEditorExtender(); htmlEditorExtender.ID = "htmlextender_" + sender.GetName(); htmlEditorExtender.TargetControlID = sender.GetName(); WebControl webctrl = new WebControl(System.Web.UI.HtmlTextWriterTag.Div); webctrl.Controls.Add(tb); webctrl.Controls.Add(htmlEditorExtender); return webctrl; } } }Field in the form part for a four questions ( Images/Text etc..., the user need to decide with image to choose etc...
using System; using System.Collections.Generic; using System.Linq; using System.Web; using Umbraco.Forms.Core; using System.Web.UI.WebControls; using System.IO; using System.Text; using umbraco.editorControls; using umb = umbraco; namespace Application.Web.FieldType { public class FourQuestions : Umbraco.Forms.Core.FieldType { public ListComment author was deleted
Ok mind sharing the code on github or as a zip as this won't work :)
Hi Tim,
I've put the code classes on GitHub - https://github.com/glyons/ContourRichTextArea
Any ideas ?
Thanks again,
Gavin
Hi Gavin,
I'm just looking at building a couple of new field types for contour with a view of removing our current corporate system, did you resolve this issue?
