  • David Brendel 792 posts 2970 karma points MVP 3x c-trib
    Jul 18, 2013 @ 12:41
    David Brendel
    Form entries not saved with license file in place
    I installed the newest version of contour in an umbraco 6.1.2 installation.
    Now when i'm adding the license file to the bin directory the trial mode banner goes away but the form values aren't saved. Instead every field got the value: empty because of trial mode.
    Has somebody got the same error? Do I have to do some more steps to get the license installed properly?
    David
  • Comment author was deleted
    Jul 18, 2013 @ 13:29
    You sure you are submitting from a domain that is part of the license? Does it also happen when you try to submit from preview mode in Contour?
    Jul 18, 2013 @ 13:58
    Also if you have other commercial packages installed make sure you are running the latest verison of our licensing software you can find it here
    http://nightly.umbraco.org/umbraco.licensing/ (just download and drop in /bin dir)
    Jul 19, 2013 @ 10:03
    David Brendel
    Ok installed the new dll file.
    Restarted the website a few times in iis then opened it in another browser and it works.
    Thanks for the help!
    Jul 19, 2013 @ 10:20
    Ok glad it's working now :)
