  • Jo Price 10 posts 30 karma points
    Jul 22, 2013 @ 11:56
    Jo Price
    Importing a form with conditional fields (Contour 3.0)
    We have recently upgraded to Contour 3.0 on a site (still working with Umbraco 4.7.1.1*) and have been unable to import forms with conditional fields into our staging environement.  The error I am getting is as follows:
    The
    INSERT statement conflicted with the FOREIGN KEY constraint
    "FK_UFFieldConditionRules_UFFields". The conflict occurred in
    database "Umbraco_db", table "dbo.UFFields", column
    'Id'. The statement has been terminated.
    I can see that contour is trying to create objects in the database in the wrong order, yet the import file is in XML not a SQL script so I cannot run this in isolation.  Is this a known issue or is there a workaround? This form needs to go live pretty soon.
    *We have a lot of custom code dependancies so upgrading Umbraco is not currently an option for us.
    Aug 05, 2013 @ 14:35
    Jo Price
    Has anyone else come across this issue?
  • Comment author was deleted
    Aug 05, 2013 @ 14:42
    Hey Jo,
    What version of Contour are you runnning?
    Aug 05, 2013 @ 14:43
    Looks like you need to be running at least 3.0.10 for it to work
    Aug 05, 2013 @ 14:44
    But that version doesn't work with your Umbraco version ... so you'll need to upgrade Umbraco...
    Aug 05, 2013 @ 14:46
    Jo Price
    Thanks for your help Tim.
    Aug 05, 2013 @ 14:58
    Jo Price
    Apparently we are running v3.0.12 of Contour - is this version incompatible with our version of Umbraco?  Would upgrading to 4.11 help?
    Aug 05, 2013 @ 15:02
    Hmm should work then, mind sending me the form export? You can send it to tg at umbraco dot com thanks
    Aug 12, 2013 @ 10:55
    Jo Price
    Tim, did you recieve the file?
  • Brian Koch 20 posts 80 karma points
    Aug 19, 2013 @ 20:49
    Brian Koch
    We are experiencing the same issue, Umbraco v 4.11.8, Latest Contour (from project page) v 3.0.14.
    Aug 20, 2013 @ 12:03
    Looking into it, update will follow today
    Aug 20, 2013 @ 12:34
    Ok I can see why this is happening so looking into a fix
    Basicly it's because the fields don't have an id in the export (it creates a new id in import) but the conditions do have the fieldid stored so it's trying to insert a condition with a field id that doesnt exist
    Aug 20, 2013 @ 12:45
    Working on the fix now, should be ready today/tomorrow
    Aug 20, 2013 @ 13:01
    Ok found a fix :)
    You'll need to update to 3.0.15 WIP version that you can find here
    http://nightly.umbraco.org/Umbraco%20Contour/3.0.15%20WIP/
    For upgrade instructions please check
    http://our.umbraco.org/projects/umbraco-pro/contour/documentation/Installation/Upgrade
    To fix you'll also need to export the form again since the new export will include the field ids and will then map them with the new ids
    Please let me know if this fixes the issue
    Regards, Tim
    Aug 20, 2013 @ 14:52
    Jo Price
    Thanks Tim,
    I'm getting the guys to test it now.
    Aug 21, 2013 @ 10:25
    Ok make sure to update both export and import instance of Umbraco :)
    Aug 22, 2013 @ 21:28
    Brian Koch
    Thanks Tim! i'm able to export and import on 2 different sites both using Contour 3.0.15WIP with conditions in the forms, and no errors.  I do have an unrelated issue, but will start a new thread..
    Thanks again!
    Brian.
    Aug 27, 2013 @ 10:37
    Jo Price
    Hello Tim,
    Sorry for the delayed response.  I can confirm that this now works, however we cannot delete a form any more, this is the message that appears:
    Aug 27, 2013 @ 10:52
    @Jo, all forms or just the imported ones?
    Aug 27, 2013 @ 15:41
    Jo Price
    @Tim forms that have been imported are having this issue
    Aug 27, 2013 @ 16:07
    Ok thanks for the extra details I'll take a look
    Sep 10, 2013 @ 13:05
    Jo Price
    Hi Tim, did you get any luck with this?
    Sep 11, 2013 @ 14:39
    @Jo not yet been on hols but will look into it this week :)
    Sep 17, 2013 @ 23:40
    Brian Koch
    Tim -
    For the record, we're also not able to delete imported forms.
    Still on contour 3.0.15 WIP here because we need to be able to export/import between staging and live / Umbraco 4.11.8
    Additionally, we are having a problem with a mandatory radio button list not passing validation when one of the items is selected (this happens in preview and also when the form is used)
    Any ideas?
    Sep 18, 2013 @ 14:03
    @Brain did you change anything to the form markup? Might be that the validation expects some classes that aren't there anymore
    Sep 18, 2013 @ 15:02
    Brian Koch
    Tim -
    Thanks for the quick response! The only change i'm aware of is to /umbraco/plugins/umbracoContour/Views/Form.cshtml - the location of the DefaultForm.css is changed to the site/css directory so our Editor can change the styles.
    I will compare the contour directories against the 3.0.15 WIP files again and let you know if any others were changed..
    Thanks again!
    Brian.
    Sep 19, 2013 @ 17:03
    Brian Koch
    Tim -
    I'm able to reproduce with a fresh install of Umbraco 4.11.8, no modifications, installed Contour 3.0.15 WIP.
    Created template to display the form adding the 4 required jQuery references for Contour version 3.x +   (jquery-1.8.2, jquery-ui, jquery.validate, and jquery.validate.unobtrusive)
    Create form with 1 mandatory radiobuttonlist and 1 conditional Textfield based on the radiobuttonlist
    Preview form from Contour editForm page (uses previewFormDialogMvc.aspx)
    Select one of the radio button list items, click submit, receive mandatory message (expected to be able to submit without receiving mandatory message here).
    Insert form on content page using "Insert form from Umbraco Contour (Razor)" macro.
    Save & Publish content form
    View in browser, select one of the radio button list items, click submit, receive mandatory message (expected to be able to submit without receiving mandatory message here).
    Tested in both IE 9, and Firefox 24. (no script errors in either browser, and conditional field is working correctly in preview / form view)
    Sep 20, 2013 @ 10:15
    Jo Price
    Hello Tim,
    We have this issue too with mandatory radio buttons.
