  • J 447 posts 864 karma points
    Aug 01, 2013 @ 10:25
    J
    FormPage and ForFieldsets
    I have a weird issue occuring. I create a form in code. I upload it and notice in the designer that i have Registration and Details (i think within the Fieldsets). I delete the text and for some reason which im not sure it reappears again.
    The initialisation of Registration and Details that i can find are
    public class Forms
        public Forms()
        public enum FormPages
            Registration
        public enum FormFieldsets
            Details
    but a little unsure how to hide the text from appearing?
  • Comment author was deleted
    Aug 01, 2013 @ 10:30
    Hey,
    A code first form will always override the manual changes made to the form...
    Aug 01, 2013 @ 10:42
    J
    So how could i stop this from happening as the user makes a change and then the two text fields reappear?
    Aug 01, 2013 @ 10:44
    J
    Better question is once the form is showing up in Contour with the text Reg and Details, how could i blank this text in code or ensure if the user changes the form it remains blank?
    You can't at this point, but can make it a config option in the next maintenance release
    Aug 01, 2013 @ 10:51
    J
    Sorry but just to double check - I cant remove those text fields. Whatever i declare in code is what will appear on the form?
    Aug 01, 2013 @ 10:55
    Yup but you can just use an empty string as the page/fieldset caption then they will be empty
    Aug 01, 2013 @ 11:04
    J
    Where would i do that? As its an Enum?
    Aug 01, 2013 @ 11:12
    Nope not as an enum, just on the form and fieldset attribute
    Aug 01, 2013 @ 11:17
    J
    Sorry a little lost now..... If i go into Umbraco > Contour > Form and make the changes to the fieldset and form properties they revert back at a later stage - unsure why though?
    Aug 01, 2013 @ 11:22
    A code first form will always override the manual changes made to the form..., so you need to make the changes to your code... or remove the code first code...
    to have an empty one in code, use empty strings as the page and fieldset caption
    [Form("my form", ShowValidationSummary = true, MessageOnSubmit = "Profile updated!")] public class Profile: FormBase { [Field("", "", Mandatory = true, DefaultValue = "{member.name}")] public string Name { get; set; }
    so this line [Field("", "",
