I have an email address on my form which is validated against the following regular expression:
^[A-Za-z0-9!#$%&'*+/=?^_`{|}~-]+(?:\.[A-Za-z0-9!#$%&'*+/=?^_`{|}~-]+)*@(?:[A-Za-z0-9](?:[A-Za-z0-9-]*[A-Za-z0-9])?\.)+[A-Za-z0-9](?:[A-Za-z0-9-]*[A-Za-z0-9])?$
When the expression is output into the markup the ampersands are HTML encoded giving the following regex:
Is there any way I can stop the ampersands from being HTML encoded?
Comment author was deleted
Yeah update the views to use Html.Raw() will also fix this in the next maintenance release
Details on customizing the views can be found here http://our.umbraco.org/projects/umbraco-pro/contour/documentation/Developer/Custom-Markup/
Issue in our tracker: http://issues.umbraco.org/issue/CON-409
Thanks Tim, your workaround works for me :)
Cool thanks for confirming :)
Ampersands in regular expressions
^[A-Za-z0-9!#$%&'*+/=?^_`{|}~-]+(?:\.[A-Za-z0-9!#$%&'*+/=?^_`{|}~-]+)*@(?:[A-Za-z0-9](?:[A-Za-z0-9-]*[A-Za-z0-9])?\.)+[A-Za-z0-9](?:[A-Za-z0-9-]*[A-Za-z0-9])?$When the expression is output into the markup the ampersands are HTML encoded giving the following regex:
^[A-Za-z0-9!#$%&'*+/=?^_`{|}~-]+(?:\.[A-Za-z0-9!#$%&'*+/=?^_`{|}~-]+)*@(?:[A-Za-z0-9](?:[A-Za-z0-9-]*[A-Za-z0-9])?\.)+[A-Za-z0-9](?:[A-Za-z0-9-]*[A-Za-z0-9])?$Is there any way I can stop the ampersands from being HTML encoded?
