  • Graham Carr 277 posts 389 karma points
    Aug 01, 2013 @ 16:04
    Graham Carr
    Smaller captcha control
    One of our clients has the requirement to add a captcha control to an existing Contour form that is used in a right-hand bar and hence space is limited at around 220px wide. I have tried using the recaptcha control built into Contour but as you know the minimum width of this control is 300px wide.
    Has anyone created or know how to implement a captcha control that would fit into a small space such as 200px wide?
    Any ideas or solutions would be greatly appreciated.
  • Comment author was deleted
    Aug 05, 2013 @ 12:51
    Haven't seen one around
    Found this on the subject of small recpatcha http://blog.cdeutsch.com/2011/03/make-recaptcha-smaller.html
    Aug 12, 2013 @ 11:34
    Graham Carr
    Hi Tim,
    Thanks for the information. I have implemented what was in the article using the Contour Contrib recaptcha control, however I have an issue in that when submitting the form, no validation is being done on the control and the form can be submitted.
    Any ideas?
    Aug 12, 2013 @ 12:00
    Hey,
    Think you'll need to do this on the default recaptcha fieldtype in the Contour core
    Aug 12, 2013 @ 14:03
    Graham Carr
    I am now using the default recaptcha fieldtype from the Contour core, however when I try to submit the form all I ever receive is that the code entered is invalid even though I can see that the code I am entering is correct. The code I am using is shown below, note the overwritten RecaptchaOptions that was needed as the default fieldtype doesn't allow the specifying of the customthemewidget. Any further ideas?
    var RecaptchaOptions = {
    theme : 'custom',
    custom_theme_widget: 'recaptcha_widget',
    tabindex : 0
    </script>
                <div id="recaptcha_widget" style="display:none">
       <div id="recaptcha_image"></div>
       <div class="recaptcha_only_if_incorrect_sol" style="color:red">Incorrect please try again</div>
       <span class="recaptcha_only_if_image" style="display:block;padding-bottom:6px;padding-top:6px;">Enter the words above:</span>
       <span class="recaptcha_only_if_audio">Enter the numbers you hear:</span>
       <input type="text" id="recaptcha_response_field" name="recaptcha_response_field" style="width:212px;" />
       <div><a href="javascript:Recaptcha.reload()">Get another CAPTCHA</a></div>
       <div class="recaptcha_only_if_image"><a href="javascript:Recaptcha.switch_type('audio')">Get an audio CAPTCHA</a></div>
       <div class="recaptcha_only_if_audio"><a href="javascript:Recaptcha.switch_type('image')">Get an image CAPTCHA</a></div>
       <div style="padding-bottom:6px;"><a href="javascript:Recaptcha.showhelp()">Help</a></div>
        src="http://www.google.com/recaptcha/api/challenge?k=6LdV_eUSAAAAADAZabPr03hTB6Fy_IkXfRBnyEXJ">
     </script>
     <noscript>
       <iframe src="http://www.google.com/recaptcha/api/noscript?k=6LdV_eUSAAAAADAZabPr03hTB6Fy_IkXfRBnyEXJ"
        height="300" width="500" frameborder="0"></iframe>
       <textarea name="recaptcha_challenge_field" rows="3" cols="40">
       </textarea>
       <input type="hidden" name="recaptcha_response_field"
            value="manual_challenge">
     </noscript>
    Aug 12, 2013 @ 15:22
    Graham Carr
    This is turning into a bit of a nightmare, I have spent a fair few hours trying to get this working but still no luck, surely there must be someone out there who has successfully implemented a custom theme to the captcha control and got it working.
    Aug 12, 2013 @ 18:08
    Graham Carr
    101
    After much trial and error I have eventually found a way of getting this working, for any other people wanting to know how to implement this in the future find the steps below:
    1. Use the default Recaptcha datatype that ships with Contour.
    2. Set the theme to custom
    3. Set the ReCaptcha Public and Private keys in the file UmbracoContour.config located in /Umbraco/Plugins/umbracoContour
    4. Change the file Fieldtype.Recaptcha.cshtml in the /umbraco/plugins/umbracoContour/Views directory to read as the attached file here (N.B. if you are using an overriden form then the updated file will need to be placed in the /umbraco/plugins/umbracoContour/Views/Forms/
      directory
    Once the above steps have been done then the custom ReCaptcha control should all work fine.
    Aug 14, 2013 @ 11:54
    Great thanks for posting the solution :)
