  • Kerry Lindsay 5 posts 25 karma points
    Aug 02, 2013 @ 16:11
    Kerry Lindsay
    Contour 3.0.6 - Cannot re-order entries
    Hi, I've upgraded to Contour 3.0.6 which works fine, but I am unable to re-order the entries in the Entries screen.  If I click on the arrow underneath "Created", a message pops up saying processing but nothing happens.
    Is there something I need to do, or is this a bug?
    Thanks, Kerry
  • Comment author was deleted
    Aug 05, 2013 @ 12:46
    Probably not supported for advanced filtering and sorting just export the records to a spreadsheet tool
