This is my first go-round with Contour and I really like it! I am stuck on one thing and hoping someone out there has some insight.
I have a simple 4 field form, nothing required, no rules...one of the fields is a file upload field. It renders and works correctly on the form, but when I recieve the email with the form values, it does not include a link to the file, or a file attachment. The attachment is also not shown in the "Entries" tab. I tried installing Contrib which seems to have more support for attachments, but I still did not get any mention of the uploaded file in my email.
I am wondering if there is anything I have to do in the config, or similar to allow sending attachments.
I am running Umbraco v6.0.6 and Contour 3.0.14, Contrib is currently uninstalled. I am adding the Razor Macro the page, not the UserControl.
Going to answer my own question here in case someone else runs up against this.
Out of desperation I decided to just start trying anything I could think of, so I tried adding the Contour form to my page as a UserControl instead of as a Macro, when I did that, I started receiving the attachment link text in my email so I re-installed Contrib and boom, attachments are on the email now.
SO, in summary, you need Contour (obviously), need the Contour Contrib package, and you need to add the macro as a user control and not as razor.
In umbraco 7.2 version its working, but i am working on 7.1.4 version and have installed contour in this version. Here it is not working. Does any one has a solution?
My SMTP server settings are fine. I am receiving the mail without the attachment even after checking the attachment option in contour.
Can you please suggest something for this?
Attachments not being sent
-Roger
Roger
Comment author was deleted
Yup the default workflows in Contour won't add uploads as attachments :)
Hi Tim,
Hey Sunil,
Maybe it's the smtp server settings, does the mail go out without attachements or you don't receive any mail?
Hi Tim,
My SMTP server settings are fine. I am receiving the mail without the attachment even after checking the attachment option in contour. Can you please suggest something for this?
