I've just been reading Tim's blog post about creating a quiz using contour. I was just wondering if it would be possible extend on this so I could create different form steps (A bit like categories) so at the end I could then show a score for each category. Also rather than the scores for each question being right or wrong it would be more of a scale, for example 1-5 on how well someone understands the questions subject?
Is this something I could do using contour and custom workflows?
Hi Tim, Thanks for the reply. My only concern is how I could group the questions, I can obviously group them on the frontend using the form steps but how would I then group them when working out the scores? Cheers Tom.
Quiz style form using contour
Cheers Tom.
Does anybody know? I have to do a costing today and it would make my life so much easier if I could use Contour for this :)
Cheers Tom.
Comment author was deleted
Hey Tom,
Well it should be possible and you can use the quiz code as a starting point but you'll need to customize it so it does what you want :)
Just update the control so you can also specify a group full sourcecode is available
So this control http://www.nibble.be/wlwimages/CreatingaQuizwithUmbracoContourD49B/image5.png
Ahh right I see. Thanks for clarifying it is possible Tim, I can now base my hours for the costing on using Contour now :) Cheers Tom.
