  • Marc Stöcker 104 posts 560 karma points c-trib
    Aug 08, 2013 @ 14:54
    Marc Stöcker
    Using RecordService to delete record results in Exception
    I thought "that will be easy", but now I'm pretty much stuck on something that looked all too easy to accomplish.
    Plan: A workflow that deletes the current record.
    Execution: Custom workflow class (see below)
    Result: Umbraco Exception (DataLayer): SQL helper exception in ExecuteNonQuery
    This is the code
    public override WorkflowExecutionStatus Execute(Record record, RecordEventArgs e)
                    using (RecordService rs = new RecordService(record))
                        rs.Delete();
                    return WorkflowExecutionStatus.Completed;
    Here are the details from UmbracoTraceLog.txt:
    2013-08-08 14:35:08,368 [30] ERROR umbraco.DataLayer.SqlHelper`1[[System.Data.SqlServerCe.SqlCeParameter, System.Data.SqlServerCe, Version=4.0.0.0, Culture=neutral, PublicKeyToken=89845dcd8080cc91]] - [Thread 19] Error executing query INSERT INTO UFRecordDataString([key], Value) VALUES(@key, @value)
    SqlCE4Umbraco.SqlCeProviderException: Error running NonQuery:
    SQL Statement:
    Exception:
    System.Data.SqlServerCe.SqlCeException (0x80004005): A foreign key value cannot be inserted because a corresponding primary key value does not exist. [ Foreign key constraint name = FK_UFRecordDataString_UFRecordFields ]
       bei System.Data.SqlServerCe.SqlCeCommand.ProcessResults(Int32 hr)
       bei System.Data.SqlServerCe.SqlCeCommand.ExecuteCommandText(IntPtr& pCursor, Boolean& isBaseTableCursor)
       bei System.Data.SqlServerCe.SqlCeCommand.ExecuteCommand(CommandBehavior behavior, String method, ResultSetOptions options)
       bei System.Data.SqlServerCe.SqlCeCommand.ExecuteNonQuery()
       bei SqlCE4Umbraco.SqlCeApplicationBlock.ExecuteNonQuery(String connectionString, CommandType commandType, String commandText, SqlCeParameter[] commandParameters)
       bei SqlCE4Umbraco.SqlCEHelper.ExecuteNonQuery(String commandText, SqlCeParameter[] parameters)
       bei umbraco.DataLayer.SqlHelper`1.ExecuteNonQuery(String commandText, IParameter[] parameters)
    Assigned to submit state
    It seems to me that this issue is reported in a similar manner here:
    http://our.umbraco.org/forum/umbraco-pro/contour/37335-Contour-Workflow-delete-record-database-error
    http://our.umbraco.org/forum/umbraco-pro/contour/23003-workflow-delete-record-not-working
    Any help would be greatly appreciated! :)
    Marc.
  • Comment author was deleted
    Aug 14, 2013 @ 11:56
    Hey,
    Could you try moving the workflow to the approved stage? And let me know if that works, thanks :)
    Aug 14, 2013 @ 12:10
    Marc Stöcker
    Sure. Tried that but got an "Object reference not set to an instance" type of error after submitting the form.
    Unfortunately I can't find details/stack trace in UmbracoTraceLog.txt for that error.
    Aug 14, 2013 @ 12:11
    Ok thanks, will give it a try and report back later today
    Aug 14, 2013 @ 14:56
    Ok fixed the problem so you can upgrade to http://nightly.umbraco.org/Umbraco%20Contour/3.0.15%20WIP/
    But please place the workflow on the approved state otherwise it won't work
    Upgrade instructions can be found here http://our.umbraco.org/projects/umbraco-pro/contour/documentation/Installation/Upgrade
    Didn't spot the forum post last week so next time ping me sooner ;)
    Aug 15, 2013 @ 21:53
    Marc Stöcker
    Wasn't too urgent, so I didn't want to be too pushy. :)
    Looks good now with 3.0.15. Working as expected.
    Thanks for your quick help, Tim!
    Aug 16, 2013 @ 09:11
    Great, thanks for confirming :)
  • Razvan 36 posts 67 karma points
    Aug 28, 2014 @ 19:58
    Razvan
    I still have this error in contour 3.0.21
    The INSERT statement conflicted with the FOREIGN KEY constraint FKUFRecordDataStringUFRecordFields. The conflict occurred in database, table dbo.UFRecordFields, column 'Key'.\r\nThe statement has been terminated.
  • Robert Brown 18 posts 38 karma points
    Sep 15, 2014 @ 20:37
    Robert Brown
    I also have this error with contour 3.0.21 & v 7.1.6.
    2014-09-15 14:29:17,513 [41] ERROR umbraco.DataLayer.SqlHelper`1[[System.Data.SqlClient.SqlParameter, System.Data, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089]] - [Thread 37] Error executing query INSERT INTO UFRecordDataString([key], Value) VALUES(@key, @value)
    System.Data.SqlClient.SqlException (0x80131904): The INSERT statement conflicted with the FOREIGN KEY constraint "FK_UFRecordDataString_UFRecordFields".
  • Kevin Lawrence 183 posts 350 karma points
    Sep 18, 2014 @ 10:00
    Kevin Lawrence
    I also receive this error too occasionally (3.0.2.1 & 7.1.1), it's completely random but it's driving us nuts as there doesn't seem to be an obvious reason for it to occur.
    Any news on this one?
