  • BenN 1 post 21 karma points
    Aug 09, 2013 @ 05:34
    BenN
    Master-detail filtering in forms
    I have a master-detail relationship that I need to filter within a form.
    For example, I have two DropDownList controls, one containing a list of Locations, and another containing a list of courses offered. I'd like to filter the list of courses based on the selected location.
    Is there any way to achieve this using Contour?
  • Comment author was deleted
    Aug 12, 2013 @ 11:07
    Nothing in there by default at this point, but something we"ll look into for version 4
    So currently you'll need to do some hacking check out this example
    http://our.umbraco.org/forum/umbraco-pro/contour/43840-Contour-Conditional-Prevalues
