Nope you can't run Contour 3 on 4.0.4.2 for that you need Contour 1.1.9 or upgrade umbraco if you wish to run Contour 3 for details on version compatibility check
I'm trying to install v1.1.9 but the installation instructions seem to be missing a step. Where do I place the actual downloaded zip file? I get the part about navigating to Developer in the Umbraco interface, then clicking on Contour, but it tells me "file not found" - surely I have to place the zip file somewhere in the folder structure for Umbraco on the server? This is the step that's missing in the instructions. Do I place it in the packages folder?
Contour compatibility with Umbraco 4.0.4.2
The company I work for has Umbraco 4.0.4.2 installed. I want to download and install Contour. Two questions:
- Is Contour 3 compatible with Umbraco 4.0.4.2, and if not, is there a version that is?
- Where do I move the downloaded Contour package to install it in Umbraco? Is it in the umbraco/developer/packages folder?
Thanks.
Comment author was deleted
http://our.umbraco.org/projects/umbraco-pro/contour
To install simply follow these instructions http://our.umbraco.org/projects/umbraco-pro/contour/documentation/Installation/Installation
