  • Jonas Nilsson 137 posts 260 karma points
    Aug 22, 2013 @ 11:19
    Jonas Nilsson
    Edit existing post
    Is there any simple way to load an existing record / form by it's record id (user should be able to edit his posts)
    Have seen some topics about this, but not any solutions.
    /Jonas
  • Comment author was deleted
    Aug 22, 2013 @ 12:17
    Yeah just feed it the record id :) are you using the razor macro then simply append ?recordGuid=anid to the query string and you should see the macro in edit mode :)
  • Scott 95 posts 277 karma points
    Sep 21, 2015 @ 15:26
    Scott
    Tim what about for the new Umbraco Forms? I've been trying to feed it with the recordGuid, however, it does not seem to work.
    I am using 7.3 and 4.1.4
    UPDATE: I actually managed to do it by adding recordid instead of recordGuid!
  • Dale McCutcheon 32 posts 135 karma points
    Mar 28, 2018 @ 13:29
    Dale McCutcheon
    Scott how did you get it to work with Record id i have tried both but neither are working for me?
    Mar 28, 2018 @ 13:31
    Dale McCutcheon
    Tim i'm using 7.10 umbraco and 7.0.1 umbraco forms and can't seem to populate my form with a record using ?recordId or recordGuid, any ideas?
    Mar 28, 2018 @ 18:32
    Scott
    Hi Dale
    I did like this:
    EditUmbracoForm
    @using ClientDependency.Core.Mvc;
    @using Umbraco.Forms.Mvc.DynamicObjects
    @using Umbraco.Forms.Core
    @using Umbraco.Forms.Core.Services
    @using Umbraco.Forms.Data.Storage
        Response.Cache.SetNoStore();
        var fuid = Model.MacroParameters["FormGuid"];
        var ruid = Request["recordid"];
        DynamicRecordList records = Library.GetRecordsFromForm(fuid.ToString());
    <select onChange="location.href='?recordid='+this.value">
        <option value="">Select record</option>
     @foreach (dynamic record in records)
         try {
        <option value="@record.Id" @(record.Id == @ruid ? " selected" : "")>@record.Id</option>
         catch (Exception ex)
             @ex.Message
    </select>
    @if(!String.IsNullOrEmpty(ruid))
        if (fuid != null)
            var s = fuid.ToString();
            var g = new Guid(s);
            Html.RenderAction("Render", "UmbracoForms", new {formId = g});
    I have edited my example so maybe it needs tweaking, I haven't tested it but it is taken from a working code.
    Don't know if you can use it, if not let med know, maybe you can show us what you have done to be able to assist you.
    Apr 03, 2018 @ 10:51
    Scott
    Dale did you get it to work?
    Aug 22, 2013 @ 12:19
    And to get the records from a certain member
    var AllEntries = Umbraco.Forms.Mvc.DynamicObjects.Library.GetRecordsFromForm("Big Fat Form Id - Guid"); var myKey = Membership.GetUser().ProviderUserKey.ToString(); var entries = AllEntries.Items.Where(i => i.MemberKey.ToString() == myKey).ToList();
    @foreach (var record in entries) {
    Aug 23, 2013 @ 08:49
    Jonas Nilsson
    Great!, that worked!
