Where do I purchase Contour v1.1.9, and how do I install?
Where do I buy Contour 1.1.9, and once I've downloaded the licensed version, what do I do with the file - ie, where do I place them in the folder structure?
I really need v1.1.9 of Contour urgently, as I have Umbraco 4.0.4.2. And if someone can tell me simply where I place the files once I've downloaded them, I'd greatly appreciate it.
I really can't find a simple explanation to this. There is a link to v1.1.9 on this page (http://our.umbraco.org/projects/umbraco-pro/contour) but I don't need to pay for it, so I'm guessing this is a trial or something. I tried installing this anyway according to the instructions at http://our.umbraco.org/projects/umbraco-pro/contour/documentation/Installation/Installation and I get a 'Server error in '/' Application' error.
Comment author was deleted
Hey Tom,
You can find an archive of older versions here http://nightly.umbraco.org/Umbraco%20Contour/Archive/
To buy a license simply use the order form on umbraco.com http://umbraco.com/products/more-add-ons/contour.aspx
Once you have a license just drop that in your /bin directory and you should be good to go
