  • Topic author was deleted
    Aug 28, 2013 @ 09:52
    Contour 3.0.15 changes
    Contour 3.0.15 is out today!
    Here is an overview of the changes:
    3.0.15 - August 2013
    Fixed: CON-402 Dictionary items and conditional logic not working
    Fixed: CON-418 Deleting record on approved state results in Object reference not set to an instance error when using MVC macro
    Fixed: CON-421 Typo in contourform.js
    Fixed: CON-420 Contour web.config modifications...
    Fixed: CON-424 Importing a form with conditional fields
    Fixed: CON-425 issue with obsolete script references in form picker datatype
    Fixed: CON-332 Contour and MySQL on umbraco v6
    You can get it from the project page http://our.umbraco.org/projects/umbraco-pro/contour
    Upgrade instructions available here http://our.umbraco.org/projects/umbraco-pro/contour/documentation/Installation/Upgrade
