The Workflow succeeds in getting some data from the formular, saving the value in a property-field picked in the workflow and saving the document specified by ID in the forumular.
The Workflow fails, however, to actually publish the document.
Here's my code for publishing (I've tried a lot of other snippets for this):
Document d = new Document(root);
d.Save();
d.Publish(d.User);
umbraco.library.UpdateDocumentCache(d.Id);
Some of this I got from a video by Niels at umbraco.tv.
By entire workflow c# file looks like this:
using System;
using System.Linq;
using System.Text;
using umbraco.BusinessLogic;
using umbraco.cms.businesslogic.web;
using umbraco.cms.businesslogic.propertytype;
using umbraco.cms.businesslogic.property;
using Umbraco.Forms.Data;
using Umbraco.Forms.Core;
using Umbraco.Forms.Core.Enums;
namespace AttackMonkey.Contour.WorkFlows
public class PublishFormAsPage : WorkflowType
public PublishFormAsPage()
this.Id = new Guid("139c868c-9bfc-41ae-85ff-cc22af63abfc");
this.Name = "Save as umbraco document - parent page from form";
this.Description = "Saves the form values as an umbraco document node with a specific type, with the parent page being selected from the form itself, rather than being a fixed node.";
[Umbraco.Forms.Core.Attributes.Setting("Document Type", description = "Map document type", control = "Umbraco.Forms.Core.FieldSetting.DocumentMapper")]
public string Fields { get; set; }
[Umbraco.Forms.Core.Attributes.Setting("Publish", description = "Publish document instantly", control = "Umbraco.Forms.Core.FieldSetting.Checkbox")]
public string Publish { get; set; }
[Umbraco.Forms.Core.Attributes.Setting("Field containing node id", description = "The field in the form that contains the node id of the page to save to", control = "Umbraco.Forms.Core.FieldSetting.FieldPicker")]
public string RootNode { get; set; }
public override WorkflowExecutionStatus Execute(Record record, RecordEventArgs e)
Dictionary<string, string> mappings = new Dictionary<string, string>();
int dtId = 0;
int root = -1;
//old code to get node id
//int.TryParse(RootNode, out root);
//new code, using the field mapping from the settings, gets the value of the field specified as containing the page id
if (record.RecordFields.ContainsKey(new Guid(RootNode)))
int.TryParse(record.RecordFields[new Guid(RootNode)].ValuesAsString(), out root);
if (root == 0)
root = -1;
string nameMapping = "NodeName";
string[] array = Fields.Trim().Split('|');
foreach (string s in array)
string[] a = s.Trim().Split(',');
if (a.Count() == 1 && s.Trim().Length >= 4)
if (dtId == 0)
int.TryParse(s.Trim(), out dtId);
else if (a.Count() == 3)
string mapping = "";
if (!string.IsNullOrEmpty(a[2]))
mapping = record.RecordFields[new Guid(a[2])].ValuesAsString();
else if (!string.IsNullOrEmpty(a[1]))
mapping = Umbraco.Forms.Core.Services.WorkflowService.parseAttribute(e.Context, record, a[1]);
if ((!string.IsNullOrEmpty(mapping)))
if (a[0] == "__nodeName")
nameMapping = mapping;
else
mappings.Add(a[0], mapping);
LogHelper.Debug(a[0] + " " + mapping);
DocumentType dt = new DocumentType(dtId);
if (dt != null)
////ensure that the question used in the url isn't stupidly long by limiting the name mapping to the first sentence
//if (nameMapping.Contains("."))
// nameMapping = nameMapping.Substring(0, nameMapping.IndexOf("."));
foreach (Property p in d.getProperties)
try
if (mappings.ContainsKey(p.PropertyType.Alias))
p.Value = mappings[p.PropertyType.Alias];
catch (Exception ex)
LogHelper.Debug(ex.ToString());
//d.Save();
/*if (Publish == true.ToString())
d.Publish(User.GetUser(0));
umbraco.library.PublishSingleNode(d.Id);
d.Save();
d.Publish(d.User);
return WorkflowExecutionStatus.Completed;
public override List<Exception> ValidateSettings()
return new List<Exception>();
The code is mainly built on the PublishFormAsPage workflow and partially on other different workflows i found.
Well.. I've tried making a workflow that has no dynamic variables passing a value into the document and publishing it. It still won't publish correctly.
The thing is, that the value I post is saved to the document by what i must assume is the...
d.Save();
...method. And since the submit method comes first thing after, I assume it reaches the method correct.
The parrent-page is published, as are all ancestors.
We seem to have the same problem when trying to publish using a 3rd party control-application calling the same API.
We're trying this on Umbraco 6.1.4 with contour 3.0.9
I'll just look into that API update and get back in a moment.
You mean the workflow using the "SaveAsUmbracoNode.cs"?
If so, the document I'm trying to publish is actually generated by that workflow. This works fine.
This, however, uses a slight different code for publishing:
d.Save();
if (Publish == true.ToString()) {
d.Publish(new umbraco.BusinessLogic.User(0));
Yeah but if the default workflow works it isn't a bug in the api , does publishing from the backoffice work on the doc that you are trying to publish from code?
Well.. If i open the document in the backend and publish it, it works.
If I right-click the document and choose publish it just keeps loading and loading and never publish it.
Well well, this might be interesting!
There are a lot of dictionary-failures in the traceLog, but this particular element grapped my attention.
2013-08-29 13:23:02,970 [47] WARN Umbraco.Web.Routing.NiceUrlProvider - [Thread 12] Couldn't find any page with nodeId=-1. This is most likely caused by the page not being published.
This might also be interesting...
2013-08-29 13:21:44,845 [47] INFO umbraco.BusinessLogic.Log - [Thread 14] Redirected log call (please use Umbraco.Core.Logging.LogHelper instead of umbraco.BusinessLogic.Log) | Type: Error | User: 0 | NodeId: -1 | Comment: SEOChecker error in PageNotFound Module: System.Threading.ThreadAbortException: Thread was being aborted.
at System.Threading.Thread.AbortInternal()
at System.Threading.Thread.Abort(Object stateInfo)
at System.Web.HttpResponse.End()
at SEOChecker.HttpModules.UrlModule.(Object , EventArgs )
Dont know if NesletterStudio might have anything to do with it.. but:
2013-08-29 13:30:39,786 [47] WARN Umbraco.Web.Routing.NiceUrlProvider - [Thread 76] Couldn't find any page with nodeId=-1. This is most likely caused by the page not being published.
2013-08-29 13:30:47,087 [47] INFO umbraco.presentation.publishingService - [Thread 37] newsletterstudioBounces has been called with response: False
2013-08-29 13:30:56,447 [47] WARN Umbraco.Web.Dictionary.DefaultCultureDictionary - [Thread 75] Error returning dictionary item 'Submit'. Exception: System.ArgumentException: No key Submit exists in dictionary
When i fill out the form and thereby activate the workflow, it saves the correct value into the document.
It just won't show on the site.
Also I get this yellow star beside the document in the backend.
Like this:
Aight!
If anyone in the future stumbles upon this, heres the solution.
(There might be a way to merge the two workflows, but I'm not going to do that).
The first workflow is to save the new values to the document.
using System;
using System.Linq;
using System.Text;
int dtId = 0;
int root = -1;
if (root == 0)
root = -1;
if (dtId == 0)
else
if (dt != null)
try
d.Save();
The next workflow is to publish the document after it's saved. The workflows also has to be put in this order, when you add them to the form in contour.
using System;
using System.Linq;
using System.Text;
using System.Web;
/*using umbraco.cms.businesslogic.propertytype;
using umbraco.cms.businesslogic.property;*/
using Umbraco.Core;
using Umbraco.Core.Persistence;
using Umbraco.Core.Services;
namespace testNewApi.Contour.WorkFlows
public class testNewApi : WorkflowType
public testNewApi()
this.Id = new Guid("746f927c-9cfd-10ea-98ba-aa67aa89cdee");
this.Name = "Publish document";
this.Description = "This needs no description!";
[Umbraco.Forms.Core.Attributes.Setting("Node ID", description = "*The ID of the document to publish", control = "Umbraco.Forms.Core.FieldSetting.TextField")]
public string NodeID { get; set; }
var context = ApplicationContext.Current;
var serviceContext = context.Services;
var contentService = serviceContext.ContentService;
int docID = Convert.ToInt32(NodeID);
var doc = contentService.GetById(docID);
contentService.SaveAndPublish(doc);
Workflow for updating existing document by ID
Hi there!
I'm trying to make a custom workflow for contour.
What the * am I doing wrong?!
Comment author was deleted
Hmm code looks ok, have you tried debugging the code to see if it actually reaches the publish method
And nothing hooked to the publish event that might prevent the publish? Is the parent page published ?
Hmm might be a bug then, mind switching to the new API's in v6 for some details check
http://umbraco.com/follow-us/blog-archive/2013/1/22/introducing-contentservice-aka-the-v6-api.aspx
Should be an easy update
Will check if the default save as umbraco document workflow still works since that also uses the old api
That still works so must be something in the code then
Can you also check if you can get the default save as umbraco document workflow publishing a doc?
You mean the workflow using the "SaveAsUmbracoNode.cs"? If so, the document I'm trying to publish is actually generated by that workflow. This works fine.
But i've tried this too.
You mean something like this?
Oh ok :)
Well.. If i open the document in the backend and publish it, it works. If I right-click the document and choose publish it just keeps loading and loading and never publish it.
Anything in the umbraco log files?
If however the document is published and I republish it by right-clicking, it also works.
Well well, this might be interesting! There are a lot of dictionary-failures in the traceLog, but this particular element grapped my attention.
2013-08-29 13:21:44,845 [47] INFO umbraco.BusinessLogic.Log - [Thread 14] Redirected log call (please use Umbraco.Core.Logging.LogHelper instead of umbraco.BusinessLogic.Log) | Type: Error | User: 0 | NodeId: -1 | Comment: SEOChecker error in PageNotFound Module: System.Threading.ThreadAbortException: Thread was being aborted. at System.Threading.Thread.AbortInternal() at System.Threading.Thread.Abort(Object stateInfo) at System.Web.HttpResponse.End() at SEOChecker.HttpModules.UrlModule.(Object , EventArgs )
2013-08-29 13:30:39,786 [47] WARN Umbraco.Web.Routing.NiceUrlProvider - [Thread 76] Couldn't find any page with nodeId=-1. This is most likely caused by the page not being published. 2013-08-29 13:30:47,087 [47] INFO umbraco.presentation.publishingService - [Thread 37] newsletterstudioBounces has been called with response: False 2013-08-29 13:30:56,447 [47] WARN Umbraco.Web.Dictionary.DefaultCultureDictionary - [Thread 75] Error returning dictionary item 'Submit'. Exception: System.ArgumentException: No key Submit exists in dictionary
Errors don't seem related
Mind sending the code file I can give it a try then?
Sharing it here would do the trick https://gist.github.com/ :)
Uhm.. yeah no problem :) I guess I posted it right, never used gist though :p
https://gist.github.com/anonymous/6414475100ad107d66eb
Thanks, will give it a try, yeah it's just easier to copy it from there then on this forum :)
Hmm publish seems to work but it's silently failing in setting the property values ...
Can you confirm that the property values do update in your case?
When i fill out the form and thereby activate the workflow, it saves the correct value into the document. It just won't show on the site. Also I get this yellow star beside the document in the backend. Like this:
But the value saves correctly, like this:
The code in the front-end form looks like this:
And the entry like this:
Can't reproduce this one :( maybe try using the new api to publish the doc and see if that has any difference?
I would, but I can't call the Services namespace from my workflow...
Is it possible that you could provide me with a working workflow using the new API?
Here is a console app that uses the new API so should give you details in how to access the services https://github.com/sitereactor/umbraco-console-example/blob/master/UmbConsole/Program.cs
Seems to be the using Umbraco.Core.Persistence; NS i was missing. This seems to work, I'll just test it and get back to you :)
Now I'm able to publish the document :) I'll merge the code and post the solution workflow here :)
Thank you very much for your time (y)
Aight! If anyone in the future stumbles upon this, heres the solution. (There might be a way to merge the two workflows, but I'm not going to do that).
I hope someone might put this into good use!
Ah sweet glad that one does the trick :)
