Hi, |I have an Umbraco 6.0.3 web site that I have installed Contour into.
Everything works i.,e. creation of form addition of fields etc and when saved, it can be previewed OK
Problem is that when i add a macro calling the form (and I choose Razor macro because site is MVC) it shows the normal yellow dotted box in the RTE field but it doesn't render in the page when the page is used for real.
Just one thing - when it was installed, it did have an instal error - something about datatype not installed but I missed saving it.
This is a site going live on Monday and I am concerned.
Umbraco Contour not rendering in MVC
Regards
Alan
Comment author was deleted
And does it work when you insert it on a template?
How are you outputting the rte field on your template, might be that in that umbraco version you need to do something extra to make it render macros
