Tim, I get this same error after attempting an upgrade from v1.1.10. I get the error when trying to run the updgrade script and when trying to access a form:
Method not found: 'umbraco.DataLayer.ISqlHelper umbraco.DataLayer.DataLayerHelper.CreateSqlHelper(System.String, Boolean)'.
Description:An unhandled exception occurred during the execution of the current web request. Please review the stack trace for more information about the error and where it originated in the code.
Exception Details:System.MissingMethodException: Method not found: 'umbraco.DataLayer.ISqlHelper umbraco.DataLayer.DataLayerHelper.CreateSqlHelper(System.String, Boolean)'.
Source Error:
Hello, I'm having the same error here. The Db upgrade script threw the error, then I ran the scripts myself, and now when loading the forms in contour or accessing them as a user, the missing method exception returns.
Also having this problem upgrading from 3.0.1 - extracted the latest update zip into the site root, and I'm now getting this error in the Contour section of the back-end:
And when going from version 1 to 3 make sure to run the upgrade wizard (details in the guide) that will execute the sql stuff and will perform some more update actions
I'm getting this error with a fresh install of Contour 3.0.15 on Umbraco 4.11.10 when I go to Contour and want to create a new form.
Also I'm seeing this message, when cliking "Umbraco Contour" even though I have configured a license with the correct domain names.
Looking forward to receive some inputs :)
No such host is known
Exception Details: System.Net.Sockets.SocketException: No such host is known
Source Error:
Contour upgrade problem
I am using Umbraco v4.11.8 and have upgraded to Contour v3.0.15 using Contour_3.0.15_upgrade.zip and running the SQL updrade script.
However I am getting an error:
Has anyone got this error before? Thanks in advance for your help.
Comment author was deleted
Hey, from what version are you upgrading, if it's from a 3x you don't need to run the sql upgrade
Hi Tim, I am upgrading from v1.1.10
Exception Details: System.MissingMethodException: Method not found: 'umbraco.DataLayer.ISqlHelper umbraco.DataLayer.DataLayerHelper.CreateSqlHelper(System.String, Boolean)'.
Source Error:
Umbraco version is 4.11.7 btw...
Ah, ok - I needed to use 3.0.6 for Umbraco 4.11.7 - ignore me.
Using the 3.0.6 update package worked for me as well.
yeah you don't need to run any sql manually just follow the upgrade guide http://our.umbraco.org/projects/umbraco-pro/contour/documentation/Installation/Upgrade
Hi Tim
Source Error:
I get this error too.
Method not found: 'umbraco.DataLayer.ISqlHelper umbraco.DataLayer.DataLayerHelper.CreateSqlHelper(System.String, Boolean)'.This is what it says in the package info.
I'm using 4.11.4 and im trying to install 3.0.15. Should i use 3.0.6 instead? Where is this documented in that case?
I have narrowed it down a bit.
Hi Johan,
You have the same probem as here:
http://our.umbraco.org/forum/umbraco-pro/contour/44971-Error-when-installing-contour
The latest version of Contour is for version 6 only.
/Dennis
Thanks Dennis, thats it! The documentation needs some updating :/
Yeah sorry about the confusion, will look into making the next version support both 4 and 6 again
Might have found a solution for v4/v6 compat can you give this a try on v4 http://nightly.umbraco.org/Umbraco%20Contour/3.0.16%20WIP/ if that works I'll release it tomorrow :)
Just did a test run on v4 and v6 latest and seems to run fine but would be great if someone else has time for a quick test :)
Awesome! Worked for me. Thanks!
Great thanks for confirming I'll get it out then before more people run into the v4 error :)
3.0.16 is out for both Umbraco v4 and v6 :)
Full details http://our.umbraco.org/forum/umbraco-pro/contour/45097-Contour-3016-changes
