  • Fuji Kusaka 2203 posts 4220 karma points
    Sep 02, 2013 @ 12:06
    Fuji Kusaka
    Umbraco Backend Crashing when uninstalling Contour
    Anyone had issues installing contour 3.015 under v4.11.8 ?
    I get this message when trying to access the backend
    Could not load file or assembly 'Umbraco.Forms.References, Version=1.0.10920.32880, Culture=neutral, PublicKeyToken=null' or one of its dependencies. The system cannot find the file specified.
    Sep 02, 2013 @ 12:24
    Fuji Kusaka
    Removing  Umbraco.Forms.Core.dll  give me more errors !!!
    Could not load file or assembly 'Umbraco.Forms.CodeFirst' or one of its dependencies. The system cannot find the file specified.
    Sep 02, 2013 @ 12:27
    Rich Green
    Hey Fuji,
    I got this recently, I copied the Contour files back from Dev server to local machine and it went away, not sure if somehow a dll got removed, or a glitch happened.
    You could trying to restore all the fresh contour dll's to your bin folder.
    Rich
    Sep 02, 2013 @ 12:36
    Fuji Kusaka
    Hey Rich,
    Tried to copied the files from Contour directly but still not working.
  • Jeavon Leopold 3074 posts 13632 karma points MVP 12x admin c-trib
    Sep 02, 2013 @ 12:50
    Jeavon Leopold
    Hi Fuji,
    I have seen this issue, I think there is a Umbraco.Forms reference left over in web.config that needs removing, try searching web.config for Umbraco.Forms
    Jeavon
    Sep 02, 2013 @ 13:45
    Fuji Kusaka
    Weird i got it working by copying Umbraco.Forms.Core, Umbraco.Forms.Core.Providers, Umbraco.Forms.Mvc , Umbraco.Forms.References, Umbraco.Forms.UI dlls...
    Sep 02, 2013 @ 13:52
    Rich Green
    Same fix for me as mentioned :)
  • Comment author was deleted
    Sep 11, 2013 @ 11:24
    Yeah it's the web.config that doesn't get updated on uninstall causing the issue, will look into a fix for this one ;) but why would you uninstall Contour :p
    Sep 11, 2013 @ 11:28
    Fuji Kusaka
    Hi Tim,
    Uninstalled contour since the installed previous version was corrupt on installation. :) By the way Tim, how can i fix Special Characters when exporting my entries to xsl?
    Sep 11, 2013 @ 12:06
    @Fuji got some more details on that, maybe start a new topic?
