  • Fuji Kusaka 2203 posts 4220 karma points
    Sep 02, 2013 @ 19:40
    Fuji Kusaka
    Using Conditional Logic with v 4.11.8
    Hi guys,
    Does anyone has any example or doc on how to use conditional logic in contour 3.0.12  under v 4.11.8 ?
    Am not sure how to proceed and how to make use of codeFirst.
    Saw a thread where  \Umbraco\plugins\umbracoContour\Views\Script.cshtml this needs to be updated but not sure where to begin with conditional Logic.
    //Fuji
    Sep 02, 2013 @ 20:13
    Fuji Kusaka
    Weird...in preview mode the conditional logic works well but when adding the macro to template where the form doesnt work !!
    Any idea anyone ?
  • Comment author was deleted
    Sep 11, 2013 @ 15:15
    Yeah conditional logic only works with the razor macro so probably you are using the usercontrol one that doesn't support it ... so just switch the macro and it should work
    Sep 13, 2013 @ 12:36
    Fuji Kusaka
    Thanks Tim. Yes indeed i got this working.
