  • Jan Bengtsson 64 posts 108 karma points
    Sep 04, 2013 @ 09:11
    Jan Bengtsson
    Hidden field issue with commas
    I've got a HiddenField type in my Contour form. Using jQuery, I dynamically try to add a comma-separated list of numbers to that field. However, when I look in Umbraco's backend the commas are gone. The numbers are there alright, but separated by space only. I'm able to use other separators, like semicolon, but not commas. I tested to give the hidden field a DefaultValue (in backend) with commas in it ("1, 3, 5") with the same result - the commas are removed.
    Is there anyone who knows if/how it's possible to correctly handle commas in a Contour hidden field?
    I'm using Contour version 1.1.12 on a Umbraco 4.7.1.1 installation. The site runs on IIS 7.5/Windows Web Server 2008 R2. Asp.Net: 4.0.
    Regards
  • Tim 1193 posts 2675 karma points MVP 4x c-trib
    Sep 05, 2013 @ 17:16
    Tim
    This still appears to be an issue in newer versions of Contour as well....... I've just tested it on 3.0.2 on a 4.8 installation. I'd guess it's something to do with the fact that it is treated as CSV so the commas are being stripped? Tim G will be able to answer this one best!
  • Comment author was deleted
    Sep 11, 2013 @ 16:00
    Hmm yeah might be that but will have a look :) Does this only happen on hidden fields? SO works fine when you enter it in a textfield?
    Sep 11, 2013 @ 16:23
    Jan Bengtsson
    Tim, it doesn't not work in text fields either - commas are removed (hadn't noticed that before).
    Sep 11, 2013 @ 16:25
    Ok thanks for confirming will take a look :)
    Sep 11, 2013 @ 16:30
    Well data is stored correctly so might be to aggressive stripping of illegal chars in the viewer, looking into that now
  • Jon Benedict 4 posts 25 karma points
    Oct 18, 2013 @ 15:31
    Jon Benedict
    Have there been any developments on this issue? I have a few sites with contour and complaints are coming in about the stripping of commas within the forms.
    Oct 21, 2013 @ 09:54
    Yeah it's just the viewer, if you export the data with the toolbar button you get the correct data
    Oct 24, 2013 @ 22:12
    Jon Benedict
    Thanks Tim! The export method you recommended works perfectly for what I needed.
