Description: An unhandled exception occurred during
the execution of the current web request. Please review the stack trace
for more information about the error and where it originated in the
code.
Source Error:
An unhandled exception was generated during the execution of the current
web request. Information regarding the origin and location of the
exception can be identified using the exception stack trace below.
Stack Trace:
Umbraco.Forms.CodeFirst.FormManager.SynchronizeForm(Type typeForm) in c:\Program Files (x86)\teamcity\buildAgent\work\fdc2f0fcbbcef310\Umbraco.Forms.CodeFirst\FormBuilder\FormManager.cs:426
Umbraco.Forms.CodeFirst.FormManager.SynchronizeForms() in c:\Program Files (x86)\teamcity\buildAgent\work\fdc2f0fcbbcef310\Umbraco.Forms.CodeFirst\FormBuilder\FormManager.cs:201
Umbraco.Forms.CodeFirst.FormManager.Synchronize() in c:\Program Files (x86)\teamcity\buildAgent\work\fdc2f0fcbbcef310\Umbraco.Forms.CodeFirst\FormBuilder\FormManager.cs:24
Umbraco.Forms.CodeFirst.UmbracoManager.Synchronize() in c:\Program Files (x86)\teamcity\buildAgent\work\fdc2f0fcbbcef310\Umbraco.Forms.CodeFirst\UmbracoManager.cs:36
Umbraco.Forms.CodeFirst.UmbracoManager.SynchronizeIfNotSynchronized() in c:\Program Files (x86)\teamcity\buildAgent\work\fdc2f0fcbbcef310\Umbraco.Forms.CodeFirst\UmbracoManager.cs:21
Umbraco.Forms.CodeFirst.ContourFormBuilderHttpModule.context_BeginRequest(Object sender, EventArgs e) in c:\Program Files (x86)\teamcity\buildAgent\work\fdc2f0fcbbcef310\Umbraco.Forms.CodeFirst\ContourFormBuilderHttpModule.cs:27
System.Web.SyncEventExecutionStep.System.Web.HttpApplication.IExecutionStep.Execute() +79
System.Web.HttpApplication.ExecuteStep(IExecutionStep step, Boolean& completedSynchronously) +164
Version Information: Microsoft .NET Framework Version:4.0.30319; ASP.NET Version:4.0.30319.18044
I have tried to update contour with latest nightly build 3.0.15 but got the same message.
Does someone have ideas about why this error occurs and how I can update My contour version to solve this.
Issue during Synchronize on umbraco v6.1.2
Hi everyone,
We are testing Umbraco Contour Code first before buying a complete licence and we cannot get our CodeFirst form being synchronize :
It fails with the following message :
Description: An unhandled exception occurred during the execution of the current web request. Please review the stack trace for more information about the error and where it originated in the code.Exception Details: System.NullReferenceException: Object reference not set to an instance of an object.
Source Error:
Regards
David
Comment author was deleted
Not sure why but will try your example and see if I can reproduce the error and then fix it :)
Can confirm the issue, getting the same YSOD, looking into fix now :)
Ah I see it's because you are using a fieldtype that uses prevalues but aren't supplying any values for it :)
So try
[Field(FormPages.Contact, FormFieldsets.Details, Type = typeof(DropDownList), Mandatory = true, Prevalues = new[] { "Matt", "Joanne", "Robert" })] public string Topic { get; set; }
For your Topic field, setting the prevalues
Should look nicer now ;)
Hi Tim,
I finally use :
Since my data source for Topic are Prevalues obtained via XPATH but you definitely solve my issue.
Ah yes you can also set it to use a prevalue source of course :) , glad it's working now!
I had same issue but with a radio Button list,
[Field("signUp", "Details",
Type = typeof(RadioButtonList),
Prevalues = new[] { "Bronze", "Silver", "Gold" },
Caption = "Package")]
public string Package { get; set; }
and was missing the pre-values , could help if the error told you which field or object was null but thanks to the above, got it orted now :).
