Method not found: 'umbraco.DataLayer.ISqlHelper umbraco.DataLayer.DataLayerHelper.CreateSqlHelper(System.String, Boolean)'.
Exception Details: System.MissingMethodException: Method not found: 'umbraco.DataLayer.ISqlHelper umbraco.DataLayer.DataLayerHelper.CreateSqlHelper(System.String, Boolean)'.
Source Error:
Error when installing contour
I just installed Contour and that went well. I can see the Contour section, but when I enter the section I get an error on the page.
It is a new umbraco installation (umbraco v 4.11.10). I havent made any content, it´s completly emty ;-)
The Contour I have installed is from the Umbraco package Repository.
This is my first Contour, so I have no ide on where to start looking for the error
Hope anybody can help me :-)
/Kate
I have just set the. Here is the error
Source Error:
Hi Kate,
Here is a post with the same issue. http://our.umbraco.org/forum/umbraco-pro/contour/44462-Contour-upgrade-problem. Mike Taylor get his problem solved by using version 3.0.6 for a version 4.11.7 of Umbraco.
You could try to uninstall the version of Contour you have install now, and the try with the version 3.0.6 and see if it´s goes better.
You can find the 3.0.6 version under the tab called Archived Files
http://our.umbraco.org/projects/umbraco-pro/contour or here http://nightly.umbraco.org/Umbraco%20Contour/Archive/
I hope this post can help you.
/Dennis
Hi Dennis
I tried it but it did not work. I got another error :-)
I installed umbraco 6 and now it works :-)
Comment author was deleted
Yeah latest version of Contour is for v6 only , sorry about the inconvenience
