After performing a manual install (copied files over from the nightly UmbracoContour_3.0.17WIP_update.zip file)
I receive the following when selecting the Contour section in the Umbraco back office:
Error Message:
Stack Trace:
at Umbraco.Forms.Data.Storage.FormStorage.GetAllForms(Boolean archived) at
Umbraco.Forms.UI.Dashboard.FormsDashboard.Page_Load(Object sender, EventArgs e)
at System.Web.Util.CalliHelper.EventArgFunctionCaller(IntPtr fp, Object o,
Object t, EventArgs e) at System.Web.UI.Control.LoadRecursive() at
System.Web.UI.Control.LoadRecursive() at System.Web.UI.Control.LoadRecursive()
System.Web.UI.Page.ProcessRequestMain(Boolean includeStagesBeforeAsyncPoint,
Boolean includeStagesAfterAsyncPoint)
Ok - trying a fresh install now, FYI - there's still an issue with the Install from package on Umbraco version 4.11.8: Installer fails with message below, and creates a directory with the same name as the site's parent folder:
For what it's worth, if i copy the files from the errant directory to the parent directory, do an uninstall of the package (but don't delete any files), re-install of the same package, the install almost works without errors (looks like the install is trying to modify the dashboard config in the wrong location).
I'm then able to get the contour working on the fresh install by adding in the required dashboard.config entries and refreshing the browser at this point. And more importantly, i'm getting the Contour dashboard, not the original error (object reference not found..).
So, i'm going to see if i can find any differences between the original site with the Object reference not found error and the "fresh" install.
Contour 3.0.17 WIP Object Reference not set error
Using Umbraco 4.11.8
Error Message:
Stack Trace:
at Umbraco.Forms.Data.Storage.FormStorage.GetAllForms(Boolean archived) at Umbraco.Forms.UI.Dashboard.FormsDashboard.Page_Load(Object sender, EventArgs e) at System.Web.Util.CalliHelper.EventArgFunctionCaller(IntPtr fp, Object o, Object t, EventArgs e) at System.Web.UI.Control.LoadRecursive() at System.Web.UI.Control.LoadRecursive() at System.Web.UI.Control.LoadRecursive() at System.Web.UI.Control.LoadRecursive() at System.Web.UI.Control.LoadRecursive() at System.Web.UI.Control.LoadRecursive() at System.Web.UI.Control.LoadRecursive() at System.Web.UI.Page.ProcessRequestMain(Boolean includeStagesBeforeAsyncPoint, Boolean includeStagesAfterAsyncPoint)
Comment author was deleted
Ok thanks for reporting, 3.0.17 will be out today so that error should also be gone by then ;)
Hmm can't reproduce, is it just the dashboard that is failing or other parts to?
Hi Tim -
Dashboard, and any embedded forms on content pages - all give Object reference not set to an instance of an object..
Will try a fresh install, and copy of files to see if it makes a difference..
Brian.
Ok thanks :)
Hmm that's strange, thanks for the feedback, will give it a go
