Msg 102, level 15, State 1, Line 1 Incorrect syntax near ''
Hi guys
I'm currently doing a manual installation of Contour and when I'm trying to run the create.sql script in my database I get this annoying error mentioned in the title above...And I'm absolutely clueless.
My database i MSSQL 2008 and I'm logged in using the administrator account.
Hi guys
The version I'm trying to install is 3.0.16.
Any pointers are very much appreciated.
Jan
Comment author was deleted
Are you running the correct script, so the one for sql server ?
http://our.umbraco.org/projects/umbraco-pro/contour/documentation/Installation/resources/createsqlserver
Hi Tim
I'll try that one - I took the create.sql from the manul installation zip here http://our.umbraco.org/projects/umbraco-pro/contour though.
Going to try the stuff from the link above and let you know :)
Jan
Yeah think the manual zip might be outdated, give that one a shot, just tried it on 2012 and that worked...
Hi Tim
Thanks a bunch, that script worked perfectly.
Would be a nice idea to fix in the package as well, no? :)
Jan
Yeah will do :)
