Hi guys
I have just followed the guide on installing Contour manually but now that I'm done going through all of the steps the Contour section is missing?
I followed the steps described here http://our.umbraco.org/projects/umbraco-pro/contour/documentation/installation/Manual
I'm installing Contour 3.0.16 on Umbraco 4.11.
In the guide thee is no mention of editing the tree config but I merged that one from a previous install...can't figure out where to look. I have also added the UI stuff in ui.xml...
Any hints appreciated.
Cheers!
Jan
Comment author was deleted
Log in as admin and then you should see the section if you edit a user..give access to the users you want :)
Doh! Off course :)
Thanks again mate...
Working perfectly now.
Great, don't forget my karma :) I'm gaining on you :p
Missing Contour section
Hi guys
Cheers!
Jan
Doh! Off course :)
Jan
