Topic author was deleted
Oct 04, 2013 @ 10:05
Contour 3.0.17 changes
Contour 3.0.17 is out today!
Here is an overview of the changes:
3.0.17 - October 2013
Fixed: CON-382 Datepicker errors on submit
Fixed: CON-438 Problem with client side validation of mandatory RadioButtonList field
Fixed: CON-439 Contour recursive property uses legacy XML schema
Fixed: CON-409 Ampersands in regular expressions get encoded
Fixed: CON-442 Validation on Custom Field Type
Fixed: CON-410 Unpublished nodes in prevalue source
Fixed: CON-380 Contour allows multiple submissions in IE
Fixed: CON-378 issues with Contour and @Html.AntiForgeryToken() within iframes
You can get it from the project page http://our.umbraco.org/projects/umbraco-pro/contour
Upgrade instructions available here http://our.umbraco.org/projects/umbraco-pro/contour/documentation/Installation/Upgrade
