  • Anders Brohäll 295 posts 561 karma points MVP c-trib
    Oct 04, 2013 @ 10:54
    Anders Brohäll
    Changes in settings not saved
    When changing settings such as "Show validation summary", or "Hide field validation labels", and saving the form it looks good. However, the settings arent getting saved when i revisit the settings page for a form.
    Im using verison 3.0.15 with a valid license.
  • Comment author was deleted
    Oct 04, 2013 @ 10:55
    Hmm that's strange will take a look
    Oct 04, 2013 @ 10:57
    Could it be that you have a code first form? Then manual changes will be overwritten...
    Anders Brohäll
    Umbraco version 6.0.5.
    Oct 04, 2013 @ 10:58
    Anders Brohäll
    Nopes, the form is built in the UI.
    Contour is upgraded a couple of times though, migh be some conflict?
    Oct 04, 2013 @ 11:00
    Can't reproduce :( yeah I would recommend to do another upgrade to make sure all files are from the same version
    Oct 11, 2013 @ 13:06
    Anders Brohäll
    This issue is soveld for some reason.
    Might've been PEBKAC.
