  • Renaldas 26 posts 56 karma points
    Oct 08, 2013 @ 10:24
    Renaldas
    Mandatory fields not showing asterix
    I have a problem, when I creating form, mandatory fields not showing asterix on frontend, but it's showing on form preview.
    could you help me,
    thanks
  • Comment author was deleted
    Oct 08, 2013 @ 10:34
    Might be due to styling on your frontend?
    Oct 08, 2013 @ 10:38
    Renaldas
    but contour is generating these fields in frontend?
    example:
    <div class="contourField firstname textfield mandatory alternating">
    <label for="e43bed9d-9259-4f92-b90a-6445cc009630" class="fieldLabel">First Name</label>
    <div><input type="text" name="e43bed9d-9259-4f92-b90a-6445cc009630" id="e43bed9d-9259-4f92-b90a-6445cc009630" class="text" value="" maxlength="500" data-val="true" data-val-required="First Name is </div>
    It should be First Name *, same when you doing preview
    Oct 08, 2013 @ 10:40
    Yup :) but if it works in preview ... sure it's the same form ?
    Oct 09, 2013 @ 09:31
    Renaldas
    Sorted, removed form and added again.. Thanks
    Oct 09, 2013 @ 10:59
    Ok glad it's fixed :)
