  • Richard Barg 358 posts 532 karma points
    Oct 10, 2013 @ 03:50
    Richard Barg
    Field Order in "Save as Umbraco Document" Random
    Tim,
    We have a document type "Bio" with 30 fields in it. In Contour, when mapping the fields, the map to fields in the dropdown list display in almost random order.
    1. What algorithm determines the order?
    2. Can that order be changed manually? For example, could it be made alphabetical?
    3. Is it possible to exclude certain fields from the dropdown (mapping) so there is less clutter?
  • Comment author was deleted
    Oct 11, 2013 @ 09:25
    It just uses the Umbraco API to fetch all properties but not sure how there are sorted
    Only way It can be changed is to create a custom settings control, if you want to do that I can provide you the sourcecode...
    Sep 03, 2014 @ 22:24
    Richard Barg
    Yes, please provide the sourcecode
