  • Richard Barg 358 posts 532 karma points
    Oct 10, 2013 @ 22:50
    Richard Barg
    Determining Map Document Order in "Save as Umbraco Document" Workflow
    When creating a Contour form, and selecting "Save as Umbraco Document" as the workflow, the list of "Map document fields" appear in a seemingly random order. How are these fields presented and is there any way to change the order?
  • Comment author was deleted
    Oct 11, 2013 @ 09:21
    Only way to change to order is to create a custom setting control, not sure what the current order is based on it just uses the Umbraco API to fetch the properties (might be sorted based on the way they appear in the backoffice)
