  • Anders Brohäll 295 posts 561 karma points MVP c-trib
    Oct 11, 2013 @ 12:01
    Anders Brohäll
    Contour 1.1.0.0 issue
    I've got a site with Contour 1.1.0.0 installed.
    In workflows, i want to send a mail to the submitters e-mail address.
    It works good when assigning email-address in the workflow to the field name called 'Email' and referring it with {Email}.
    However, it doesnt work if the field is called something with spaces, e.g. 'Email address', refferred with {Email address}. Neither with dictionary references like '#Contour/Email' refferred with {#Contour/Email}
    Is this a know issue in that version?
    Is there a workaround?
    Unfortunately an upgrade is'nt really an option.
  • Fuji Kusaka 2203 posts 4220 karma points
    Oct 11, 2013 @ 15:02
    Fuji Kusaka
    Hi Anders,
    You should remove the blank space between {Emai address} to {Emailaddress}.
    Oct 11, 2013 @ 15:29
    Anders Brohäll
    ... well, thats just the issue.
    I don't want fields in the front-end of the rendered form called EmailAddress.
    I understand why it's a problem, but i cant be the only user that condiders this an issue.
