  • Mike Taylor 155 posts 353 karma points
    Oct 14, 2013 @ 13:50
    Mike Taylor
    URL rewrite and Contour dependencies...
    Hi there
    I have a site that uses IIS URL Rewrite to move a querystring parameter (country) into the main URL - for example...
    http://www.mydomain.com/mypage?country=gb
    ...would become...
    http://www.mydomain.com/gb/mypage
    That's all fine, but when I place a Contour form on a page, it is applying that rewrite to the injected JS and CSS dependencies, for example, in the source code of the page:
    <script src="/gb/umbraco/plugins/umbracocontour/scripts/frontend/contourform.js"...
    <link rel="stylesheet" type="text/css" href="/gb/umbraco/plugins/umbracocontour/css/defaultform.css"...
    I can't figure out why it's putting the rewritten parameter into these source URLs...
    Any ideas how I can prevent this?
    Mike
  • Comment author was deleted
    Oct 14, 2013 @ 13:59
    Hmm that's strange will see if I can reproduce
    Oct 14, 2013 @ 15:58
    Mike Taylor
    Thanks Tim, appreciate the help. If it helps, I'm currently using Umbraco 4.11.7 and Contour 3.0.1 - but there is a plan to upgrade both to latest versions. Let me know if you need me to send you over my web.config rewrite rules.
    Mike
    Oct 21, 2013 @ 10:05
    Been running courses last week so sorry for the delay, working on the contour support backlog today so will also handle this one
