  • Paul Podczervinski 1 post 21 karma points
    Oct 15, 2013 @ 19:07
    Paul Podczervinski
    Editing Entries / Importing Entries
    I am very interested in purchasing Contour but I have a couple questions first:
    1. Can I import data into the Entries?
    2. Can I edit the entries from within Umbraco?
    We are taking a serious look at utilizing Umbraco for our official website. We have a few pages which query SQL for the visitor and display results depending upon the visitor's choices.
    Thank you!
  • Comment author was deleted
    Oct 21, 2013 @ 10:06
    1) no default import tools in there but there is an api you can use to write your own import code 2) yes you can edit each record
    Also if you install Contour you can give it a go without a license if you run it locally
