Using Contour v3.0.17 with Umbraco v6.1.6 and strangely today a production site was reporting "Object reference not set to an instance of an object." for all Contour forms on the front end and every dialog in the UI was also displaying YSOD.
Example full error from log file below. An application pool recycle and all working fine again, not sure if it's something to worry about..?
2013-10-22 20:23:21,663 [34] ERROR Umbraco.Core.UmbracoApplicationBase - [Thread 34] An unhandled exception occurred
at Umbraco.Forms.Data.Storage.FormStorage.GetAllForms(Boolean archived)
at Umbraco.Forms.UI.Trees.LoadForm.Render(XmlTree& tree)
at umbraco.presentation.webservices.TreeDataService.LoadTree(TreeRequestParams treeParams)
at umbraco.presentation.webservices.TreeDataService.GetXmlTree()
at umbraco.presentation.webservices.TreeDataService.ProcessRequest(HttpContext context)
at System.Web.HttpApplication.CallHandlerExecutionStep.System.Web.HttpApplication.IExecutionStep.Execute()
at System.Web.HttpApplication.ExecuteStep(IExecutionStep step, Boolean& completedSynchronously)
2013-10-22 20:24:33,947 [9] ERROR Umbraco.Core.UmbracoApplicationBase - [Thread 9] An unhandled exception occurred
I have hit something similar when upgrading Contour from v3.0.6 to v3.0.17 on Umbraco v4.11.8. It has taken the whole site down. We have a lot of code first forms on this site.
Umbraco.Forms.Data.Storage.FormStorage.GetAllForms() +105
Umbraco.Forms.CodeFirst.FormManager.SynchronizeForm(Type typeForm) in c:\Program Files (x86)\teamcity\buildAgent\work\fdc2f0fcbbcef310\Umbraco.Forms.CodeFirst\FormBuilder\FormManager.cs:214
Umbraco.Forms.CodeFirst.FormManager.SynchronizeForms() in c:\Program Files (x86)\teamcity\buildAgent\work\fdc2f0fcbbcef310\Umbraco.Forms.CodeFirst\FormBuilder\FormManager.cs:201
Umbraco.Forms.CodeFirst.FormManager.Synchronize() in c:\Program Files (x86)\teamcity\buildAgent\work\fdc2f0fcbbcef310\Umbraco.Forms.CodeFirst\FormBuilder\FormManager.cs:24
Umbraco.Forms.CodeFirst.UmbracoManager.Synchronize() in c:\Program Files (x86)\teamcity\buildAgent\work\fdc2f0fcbbcef310\Umbraco.Forms.CodeFirst\UmbracoManager.cs:36
Umbraco.Forms.CodeFirst.UmbracoManager.SynchronizeIfNotSynchronized() in c:\Program Files (x86)\teamcity\buildAgent\work\fdc2f0fcbbcef310\Umbraco.Forms.CodeFirst\UmbracoManager.cs:21
Umbraco.Forms.CodeFirst.ContourFormBuilderHttpModule.context_BeginRequest(Object sender, EventArgs e) in c:\Program Files (x86)\teamcity\buildAgent\work\fdc2f0fcbbcef310\Umbraco.Forms.CodeFirst\ContourFormBuilderHttpModule.cs:27
System.Web.SyncEventExecutionStep.System.Web.HttpApplication.IExecutionStep.Execute() +136
System.Web.HttpApplication.ExecuteStep(IExecutionStep step, Boolean& completedSynchronously) +69
Thanks Tim, no it didn't want to come back at all until I restored the backup files. This is the dev site which is on Contour v3.0.6 but the live site is on v3.0.14 both on Umbraco 4.11.8. I want to upgrade to get round this issue: Using RecordService to delete record results in Exception1
Ok, so I also get the error upgrading from v3.0.6 to v3.0.16. Everything is fine when I upgrade to v3.0.14 but this does not get me where I need to be. Upgrading to Umbraco v6 is not currently an option.
Great, thanks Tim. I created a fresh Umbraco v4.11.8 instance, added Contour v3.0.17 and dropped in my forms dll and I can see the forms on the dashboard fine and they display on a template ok (although there is no Contour tree or section icon - I think this might have been the Umbraco permissions were not set when I installed Contour)
It might be worth mentioning that I also have the 'Could not load control: '/usercontrols/dashboards/ContactFormlogs.ascx' and 'EmailAFriendFormlogs.ascx' errors on the content dashboard - there's no starter kit installed so it must have come from Contour?
Thanks Tim, it's all sorted. On the strength of Contour working in a fresh install, I applied the upgrade to the live site and everything works perfectly. So sorry - there must be something up with the dev site!
Using Contour v3.0.17 with Umbraco v6.1.6 and strangely today a production site was reporting "Object reference not set to an instance of an object." for all Contour forms on the front end and every dialog in the UI was also displaying YSOD. Example full error from log file below. An application pool recycle and all working fine again, not sure if it's something to worry about..?
Comment author was deleted
Hmm can't really see what's going on from the stacktrace let me know if this happens again but for now this is the only case I have ever seen...
I had to degrade controur from 3.0.17 to 3.0.14 to make it work locally. Now I got the same problem when I try to upgarde from 3.0.14 to 3.0.19
Stack Trace:
Version Information: Microsoft .NET Framework Version:4.0.30319; ASP.NET Version:4.0.30319.18055I've got a simular issue when I try to upgrade contour from version 3.0.6 to 3.0.17 on localhost. This is an umbraco version 4.11.3.
[NullReferenceException: Object reference not set to an instance of an object.] Umbraco.Forms.Data.Storage.FormStorage.GetAllForms() +105 Umbraco.Forms.CodeFirst.FormManager.SynchronizeForm(Type typeForm) in c:\Program Files (x86)\teamcity\buildAgent\work\fdc2f0fcbbcef310\Umbraco.Forms.CodeFirst\FormBuilder\FormManager.cs:214 Umbraco.Forms.CodeFirst.FormManager.SynchronizeForms() in c:\Program Files (x86)\teamcity\buildAgent\work\fdc2f0fcbbcef310\Umbraco.Forms.CodeFirst\FormBuilder\FormManager.cs:201 Umbraco.Forms.CodeFirst.FormManager.Synchronize() in c:\Program Files (x86)\teamcity\buildAgent\work\fdc2f0fcbbcef310\Umbraco.Forms.CodeFirst\FormBuilder\FormManager.cs:24 Umbraco.Forms.CodeFirst.UmbracoManager.Synchronize() in c:\Program Files (x86)\teamcity\buildAgent\work\fdc2f0fcbbcef310\Umbraco.Forms.CodeFirst\UmbracoManager.cs:36 Umbraco.Forms.CodeFirst.UmbracoManager.SynchronizeIfNotSynchronized() in c:\Program Files (x86)\teamcity\buildAgent\work\fdc2f0fcbbcef310\Umbraco.Forms.CodeFirst\UmbracoManager.cs:21 Umbraco.Forms.CodeFirst.ContourFormBuilderHttpModule.context_BeginRequest(Object sender, EventArgs e) in c:\Program Files (x86)\teamcity\buildAgent\work\fdc2f0fcbbcef310\Umbraco.Forms.CodeFirst\ContourFormBuilderHttpModule.cs:27 System.Web.SyncEventExecutionStep.System.Web.HttpApplication.IExecutionStep.Execute() +136 System.Web.HttpApplication.ExecuteStep(IExecutionStep step, Boolean& completedSynchronously) +69
Also working fine after app pool restart?
so I might just go up to v3.0.15 for now?
correction, I will try v3.0.16 as 3.0.15 doesn't like Umbraco v4
Ok will try to reproduce, any chance you can try to deploy your forms to a fresh Umbraco instance with Contour just to see if that works?
Ok so it's sorted? No errors aren't from Contour sounds like something from a starter kit :)
Ok great :)
