  • Chris Etchells 6 posts 57 karma points
    Nov 11, 2013 @ 13:21
    Chris Etchells
    Custom workflow post to url or external url
    I want to add some custom fields using the post to url workflow.
    Where can I get a copy of that workflow to edit?
    Or how does it handle the posting of the form.
    Also, I've seen a few posts about posting the form to an external url, does anyone have an example of that, where you are redirected to the external url. Basically  a simple form post, but dynamically post the contour data and redirect. None of the examples I've found seem to work.
  • Comment author was deleted
    Nov 11, 2013 @ 13:22
    Hey,
    Sourcecode for all default providers is available here http://our.umbraco.org/FileDownload?id=5060
    So you can update the existing one :)
    Nov 11, 2013 @ 13:33
    Chris Etchells
    If I wanted to also redirect, is that possible?
    I need to post to a payment provider, I 've seen an example for nextbanx which seemed to response write a form to the page and submit it with javascript. I can't get that part to work.  Any suggestions, I'm sure this would be a useful workflow for others?
    Nov 11, 2013 @ 13:35
    Haven't done that but should be possible, you can place a form in edit mode by passing it the record id
