  • David 8 posts 90 karma points
    Nov 14, 2013 @ 17:00
    David
    Image upload problems
    I'm using Umbraco v6.0.3 and Contour v3.0.14
    I'm trying to submit a form with an image upload field. When I select submit, a hyperlink appears saying "Show current file"...
    In the workflow I have a 'Submit email' step when submitted (which works with other Contour forms I have created). ...and if I remove the file upload field it works!
    Am I missing something?
    Nov 14, 2013 @ 17:21
    David
    Strangely, when I preview the page it works fine, submits the image and appears in the entries list...
    Nov 14, 2013 @ 18:11
    David
    Update - removed the file upoad and inserted new. Then inserted macro "Insert macro from Umbraco Contour (Usercontrol)" rather than "Razor" and it appears to be working.
