  • William Charlton 171 posts 218 karma points
    Nov 14, 2013 @ 17:46
    William Charlton
    Tooltips aren't tooltips
    I have just created a Contour form and added tooltips to some of the fields. On the front end (HTML output) they just show as text below the fields. I see the HTML is a <div> inside the contour field and label wrapper <div> and after the actual field so presumably there should be some javascript or something to control (hide/show) this. I could fiddle with the css to get this to work but am concerned that someting is missing.
  • Comment author was deleted
    Nov 14, 2013 @ 18:01
    Hey William,
    You can update the markup if you have a specific requirement, please check http://our.umbraco.org/projects/umbraco-pro/contour/documentation/Developer/Custom-Markup/
    Nov 15, 2013 @ 13:57
    William Charlton
    Tim,
    Thanks for the tip, I'll change to the Razor version then ;)
    I does seem odd that the tooltip doesn't act as a tooltip in the first place though.
    PS Separate is spelt with an a, from the Latin se (apart) and parare (prepare). It might be useful to remember a part apart is not a pert apert. It's a common mispelling but I notice it in several places in Contour and the documentation.
    Nov 22, 2013 @ 11:38
    Ok thanks for the tips :)
    Nov 22, 2013 @ 11:54
    William Charlton
    You are very welcome, I'd expect you to correct my Dutch (die tussen haakjes onzin is) too ;)
