  • Stephen 94 posts 255 karma points
    Nov 20, 2013 @ 17:04
    Stephen
    Pop up When mandatory fields not completed
    Hi All,
    I am hoping someone can point me in the right direction here.
    Bascially I want a nice big OK popup box to appear saying, "you have not completed all mandatory fields, your for will not be submitted until an mandatory fields are complete".
    I started taking a look, but in all honesty I don't even know where to start.
    Thanks for any help you can offer.
    Nov 21, 2013 @ 21:58
    Stephen
    I have looked at adding something to the "When the form has been PartiallySubmitted" part of the workflow, but again, I can't see anything directly related to doing this, any suggestions?
    Any help appreciated.
  • Comment author was deleted
    Nov 22, 2013 @ 11:01
    In that case you'll need to hook into the client side validation, contour is just using jquery validate so I would recommend that you search in that direction
