Hi people
I am trying to customize the razor template form on Contour 3.0.17 (trial mode), on a local environment,
following this video:
http://umbraco.com/follow-us/blog-archive/2012/11/8/contour-30-features-full-control-over-form-markup.aspx
THE PROBLEM is that there are no files available under my Views folder , so I can´t make the edit I need to do
http://screencast.com/t/EeeLnjyS
Would appreciate very much any help on understanding whats going on.
Antonio
My UMbraco version is Umbraco v6.1.6 (Assembly version: 1.0.5021.24867)
my stupidity, they are here:
"The views can be found in the ~\Umbraco\plugins\umbracoContour\Views directory"
Comment author was deleted
Ok glad it's solved :) more details can be found here http://our.umbraco.org/projects/umbraco-pro/contour/documentation/Developer/Custom-Markup/
Contour Razor Views files not found?
Hi people
Antonio
