Ah it seems if the Umbraco directory isn't there, Courier won't work either.
From a security point of view, I'll have to go about it in a different way.
Would be quite nice if the Contour files where in the App_Plugins directory, would make deployment & upgrades easier :)
Removing /Umbraco in Production environments.
I've noticed Contour is storing the XSLT files for email transforms within the Umbraco directory.
Does this mean it is not possible to remove the Umbraco directory on a production environment using Contour?
I'd like to fully remove Umbraco access in production, and just use Courier to push content to LIVE.
Best wishes, Laurence
Comment author was deleted
Yeah you'll need to leave some files in there, that are used to transform emails :)
Ah it seems if the Umbraco directory isn't there, Courier won't work either. From a security point of view, I'll have to go about it in a different way.
Yup that's the plan for 3.1 :)
