  • Simon Hewitt 65 posts 126 karma points
    Dec 11, 2013 @ 12:31
    Simon Hewitt
    Conditional logic in workflow
    Is there any way to retreive the conditional logic set against a field in a workflow?
    I'd like to be able to send an email using only the relevant fields rather than the blanket iterate all fields in the record but I'm not sure how I would go about it.
    Many thanks
    Simon
  • Fuji Kusaka 2203 posts 4220 karma points
    Dec 11, 2013 @ 13:17
    Fuji Kusaka
    Hi Simon,
    In your workflow you can make use of Send Xslt transformed email and choose what field you want to display depending on if the field is choosen or not.
    That might help you .http://stackoverflow.com/questions/11037192/xslt-create-hyperlink-for-umbraco-form-in-contour
  • Comment author was deleted
    Dec 11, 2013 @ 15:49
    Yeah you can fetch it using the API
    Umbraco.Forms.Core.Field has a fieldcondition that has rules
    So you can get it in the workflow e.Form.AllFields
    Dec 12, 2013 @ 11:36
    Simon Hewitt
    Thankyou both,
    I've marked Tims as its exactly what I was hoping for but must have missed it in the API documentation.
    Cheers
    Simon
