  • Mark 122 posts 255 karma points
    Dec 16, 2013 @ 10:57
    Mark
    Exporting to CSV stripping out commas
    Hi there,
    Just downloaded the latest package / update (3.0.18) and we're finding that when we export to csv or save as csv, commas are being completely stripped out from fields. Is there any chance we can see this fixed asap :-) as it's not terribly useful in it's current state when we're trying to export addresses which need the commas?
    Many thanks,
    Mark
  • Jeroen Breuer 4909 posts 12266 karma points MVP 6x admin c-trib
    Dec 16, 2013 @ 12:05
    Jeroen Breuer
    If it's a bug you can report it here: http://issues.umbraco.org/issues/CON#newissue=yes
    Jeroen
    Dec 16, 2013 @ 13:37
    Mark
    Issue reported, many thanks.
    Mark
