  • Brian Thomson 15 posts 45 karma points
    Dec 28, 2013 @ 11:42
    Brian Thomson
    Problem since trying to install contour
    Hi there
    Apologies I have posted this in another section but now wondering if it would be better in Contour thread as this is where the problem started.
    I am a bit of a novis and been using Umbraco for a while and enjoying it. I tried to instal a version of contour however since my DB was mySQL I think this has casused problems. Contour would always give an error immediatley after installing however everything seemed to be ok but I have gone in to the site today and I am getting an error on the back end. Everything in the front end seems to be working fine - it is only after logging into Umbraco that I get this error:
    Could not load type 'Umbraco.Web.WebApi.UmbracoApiController' from assembly 'umbraco, Version=1.0.4869.17901, Culture=neutral, PublicKeyToken=null'.
    The Stack Trace is below - I really don't know too much about all the .net stuff which is why I liked umbraco so much so it has taken me out of my depth. Any pointers would be very much appreciated.
    [TypeLoadException: Could not load type 'Umbraco.Web.WebApi.UmbracoApiController' from assembly 'umbraco, Version=1.0.4869.17901, Culture=neutral, PublicKeyToken=null'.]
    System.Reflection.RuntimeAssembly.GetExportedTypes(RuntimeAssembly assembly, ObjectHandleOnStack retTypes) +0
    System.Reflection.RuntimeAssembly.GetExportedTypes() +38
    Umbraco.Core.TypeFinder.GetTypesWithFormattedException(Assembly a) +42
    Umbraco.Core.TypeFinder.GetTypes(Type assignTypeFrom, IEnumerable`1 assemblies, Boolean onlyConcreteClasses) +134
       Umbraco.Core.TypeFinder.GetAssignablesFromType(IEnumerable`
    1 assemblies, Boolean onlyConcreteClasses) +63
    Umbraco.Core.TypeFinder.FindClassesOfType(IEnumerable`1 assemblies, Boolean onlyConcreteClasses) +59
       umbraco.BusinessLogic.Actions.Action.<ReRegisterActionsAndHandlers>b__1() +35
       Umbraco.Core.ObjectResolution.LazyManyObjectsResolverBase`
    2.<get_InstanceTypes>b__5(Func`1 x) +7
       System.Linq.<SelectManyIterator>d__14`
    2.MoveNext() +238
    System.Linq.Buffer`1..ctor(IEnumerable`1 source) +217
    System.Linq.Enumerable.ToArray(IEnumerable`1 source) +78
    2.get_InstanceTypes() +626
    Umbraco.Core.ActionsResolver.CreateInstances() +69
    Umbraco.Core.ObjectResolution.ManyObjectsResolverBase`2.get_Values() +569
       umbraco.BusinessLogic.Actions.Action.GetJavaScriptFileReferences() +22
       umbraco.cms.presentation._umbraco.RenderActionJS() +43
       umbraco.cms.presentation._umbraco.Page_Load(Object sender, EventArgs e) +1824
       System.Web.Util.CalliHelper.EventArgFunctionCaller(IntPtr fp, Object o, Object t, EventArgs e) +14
       System.Web.Util.CalliEventHandlerDelegateProxy.Callback(Object sender, EventArgs e) +35
       System.Web.UI.Control.OnLoad(EventArgs e) +91
       umbraco.BasePages.BasePage.OnLoad(EventArgs e) +14
       System.Web.UI.Control.LoadRecursive() +74
       System.Web.UI.Page.ProcessRequestMain(Boolean includeStagesBeforeAsyncPoint, Boolean includeStagesAfterAsyncPoint) +2207
  • Comment author was deleted
    Jan 07, 2014 @ 16:59
    What is the Umbraco version you are running? Seems like that doesn't have api controllers yet, so just install previous verison of Contour or upgrade your Umbraco install
