I was taking Umbraco v7.0.1 for a spon today and tried to install Contour 3.0.18 onto it, directly from the package repository.
Trying to do so
1) resulted in quite a few warnings regarding the package containing legacy Property editors
Legacy Property editors detected
Read more...
This package contains legacy property editors which are not compatible with Umbraco 7
This package may not function correctly if the package developer has not indicated that it is compatible with version 7. Any > DataTypes this package creates that do not have a Version 7 compatible property editor will be converted to use a
Label/NoEdit property editor.
2) An error during installation:
3) After this error, the package appears to have been installed but there is no corresponding tab:
Nonetheless, both installer ascx and umbraco.Forms.UI.dll seem to be in place.
Re-trying the installation throws up additional warnings but eventually proceeds as expected.
It is therefore possible to get things running but it might not be the best user experience and/or might throw off beginning users.
Installation failure - Contour 3.0.18 on v7.0.1 from repo
Trying to do so
Kris
Comment author was deleted
Ok looks like an error with the post install usercontrol, will try to reproduce
HI there, Have to fix this problem ? I face the same issue also , when i try to install Digibiz Advanced Media Picker,
