    Jan 09, 2014 @ 17:01
    Ismail Mayat
    AjaxControl Toolkit issue
    I have an umbraco 452 site with contour, been running fine for quite a while, however on a deep page i found this error which I am sure started after installing contour,
    Error creating usercontrol (/usercontrols/PinCodeTracking/Edit/ExpressRegister.ascx) c:\Windows\Microsoft.NET\Framework64\v4.0.30319\Temporary ASP.NET Files\root\d761d259\31e02c43\AppWebexpressregister.ascx.a84f041d.gqft8ep.0.cs(513): error CS0433: The type 'AjaxControlToolkit.PasswordStrength' exists in both 'c:\Windows\Microsoft.NET\Framework64\v4.0.30319\Temporary ASP.NET Files\root\d761d259\31e02c43\assembly\dl3\511da1a2\278f6f354c0dcf01\Umbraco.Forms.References.DLL' and 'c:\Windows\Microsoft.NET\Framework64\v4.0.30319\Temporary ASP.NET Files\root\d761d259\31e02c43\assembly\dl3\3edf755d\45fc8f1e_4c0dcf01\AjaxControlToolkit.DLL'
    In my web.config under run time I have,
    <runtime>
    <assemblyBinding xmlns="urn:schemas-microsoft-com:asm.v1">
      <!-- Old asp.net ajax assembly bindings -->
      <dependentAssembly>
        <assemblyIdentity name="System.Web.Extensions" publicKeyToken="31bf3856ad364e35" />
        <bindingRedirect oldVersion="1.0.0.0-1.1.0.0" newVersion="4.0.0.0" />
      </dependentAssembly>
      <dependentAssembly>
        <assemblyIdentity name="System.Web.Extensions.Design" publicKeyToken="31bf3856ad364e35" />
    </assemblyBinding>
    Am I missing something?
    Regards
    Ismail
  • Comment author was deleted
    Jan 09, 2014 @ 17:14
    Flush temp files
    LAtest version 3.0.18 doesn't have ajaxcontroltoolkit so if you can upgrade
    Jan 09, 2014 @ 17:15
    Ismail Mayat
    will latest contour work with umbraco 452?
    Regards
    Ismail
    Jan 09, 2014 @ 17:20
    Don't think so :( is that page using something from the ajaxcontroltoolkit? Try using the merged one in forms.references then and remove the plain one
    Jan 09, 2014 @ 17:23
    Ismail Mayat
    The page has usercontrol on there that uses password strength control. I think your right ill have to remove the reference to existing one and reference to merged one.
    Regards
    Ismail
