  • Fuji Kusaka 2203 posts 4220 karma points
    Jan 13, 2014 @ 06:58
    Fuji Kusaka
    Custom Label
    I have a custom label that i would like to display making use of the conditional logic in contour.
    In addittion i created a custom textField as well, and depending if any value is enter in the textField i would like to display the Label.
    Here is the code for the labelling.
    using System;
    using System.Linq;
    using System.Web;
    using Umbraco.Forms.Core;
    using Umbraco.Forms.CodeFirst;
    using Umbraco.Forms.Core.Controls;
    using System.Web.UI.WebControls;
    using Umbraco.Forms.Data;
    namespace SCTextField
        public class DCLabel : FieldType
            [Umbraco.Forms.Core.Attributes.Setting("Allocation ", description = "Enter the text to show in the label", control = "Umbraco.Forms.Core.FieldSetting.TextField")]
            public string LabelToShow { get; set; }
            public System.Web.UI.WebControls.TextBox lblBox;
            public List<Object> Value;
            public DCLabel(){
                //Provider
                this.Id = new Guid("2c9be796-5fe0-4fa6-8896-4f73c0c55a73");
                 this.Name = "Label Allocation Text Field";
                 this.Description = "A Read Only Field use to display Allocation ";
                 this.Icon = "Label.png";
                 this.DataType = FieldDataType.Integer;
                 lblBox = new TextBox();
                 Value = new List<object>();
            public override WebControl Editor
                get
                    lblBox.Controls.Add(new System.Web.UI.LiteralControl("<p>" + umbraco.library.ReplaceLineBreaks(LabelToShow) + "</p>"));
                    if (Value.Count > 0)
                        lblBox.Text = Value[0].ToString();
                    else if (LabelToShow != null && LabelToShow != string.Empty)
                        lblBox.Text = StringHelper.ParsePlaceHolders(HttpContext.Current, LabelToShow);
                    return lblBox;
                set
                    base.Editor = value;
            public override List<object> Values
                get
                    if (lblBox.Text != "")
                        Value.Clear();
                        Value.Add(lblBox.Text);
                    return Value;
                set
                    Value = value;
            public override bool SupportsPrevalues
                get
                    return false;
            public override string RenderPreview()
                return "<p>" + umbraco.library.ReplaceLineBreaks(LabelToShow) + "</p>";
            public override string RenderPreviewWithPrevalues(List<object> prevalues)
                return RenderPreview();
    Can someone point out what is wrong here ?
    Jan 13, 2014 @ 07:28
    Fuji Kusaka
    Looks like even my submit is not working. I get an error when submitting the form "Input string was not in a correct format."
  • Comment author was deleted
    Jan 13, 2014 @ 09:22
    Mind sending the code then I can test, don't spot what is wrong, and copy /pasting from the forum isn't that easy ;)
    Jan 13, 2014 @ 09:58
    Fuji Kusaka
    Can you send me your email add ?
    Jan 14, 2014 @ 13:00
    yeah just use tg at umbraco dot com and I'll take a look
