  • Martin Griffiths 826 posts 1269 karma points c-trib
    Jan 13, 2014 @ 11:21
    Martin Griffiths
    Form Picker datatype not upgraded for Umbraco 7
    Hi Tim
    This one is a show stopper for me! When will this property editor be upgraded as part of Contours' compatibility with Umbraco 7?
    Otherwise it seems to work quite well. So far.
    Regards
    Martin
  • Comment author was deleted
    Jan 14, 2014 @ 13:00
    It's already in there Martin :) but I think you need to create a datatype manually and then select form picker, let me know if that doesn't work
    Jan 14, 2014 @ 14:04
    Martin Griffiths
    Derrr, silly me!
    Thanks Tim, all sorted.
    Martin
    Jan 14, 2014 @ 14:16
    Great :)
    Jan 14, 2014 @ 15:25
    Martin Griffiths
    Actually Tim whilst we are on the subject
    Can you consider the following screenshot from my recent site upgrade to Umbraco 7...
    First things first (minor niggle) the labels at the top of the UI dont vertically align with the dropdowns, sorry to be picky!
    Secondly and this has been a niggle of ours for some time...
    We have some pretty large forms which ultimately end up scrolling horizontally off of the page/pane. Can you tweak the UI slightly so that ONLY the table scrolls rather than taking all of the top and bottom UI with it? It will make the UI easier to navigate in these conditions.
    A good example I can give is picking from the MNTP, You can scroll through the tree but the confirm buttons sit outside of the box, and dont inhibit the user.
    Martin
    Jan 14, 2014 @ 15:49
    Yeah that needs some UI love, thank for the feedback :) If you could add an issue to http://issues.umbraco.org/issues/CON
    Jan 14, 2014 @ 15:53
    Martin Griffiths
    Done!
